Date/Time: Sat, 15 Mar 2025 07:48:37 +0000
Add SIM Account
View Count: 754
[2022-07-18 15:19:58] |
Mattc55 - Posts: 97 |
Hello, is it possible to add another sim account to my main instance of SC?
[2022-07-18 16:44:50] |
We recommend using the Simulated Trading Service and you yourself can add simulation accounts through that service. Refer to: Simulated Futures Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
