Date/Time: Sat, 15 Mar 2025 07:53:29 +0000
Volume > specified Amount Traded in T&S Window
View Count: 424
[2022-07-18 13:08:00] |
Stav - Posts: 104 |
Hi Sierra Chart, I've looked at the T&S settings and I have done this. Do Not Combine - Ticked Input Filtering Volume >- 20 Highlight & Alert Volume >- 20 Do I need to do anything else to only show when 20+ Volume get traded in the Time & Sale? Thanks for your kind attention. Stephen |
[2022-07-18 13:35:27] |
This looks correct.
[2022-07-18 13:43:22] |
Stav - Posts: 104 |
Hi, Thanks. Stephen |
[2022-07-18 14:30:29] |
Stav - Posts: 104 |
Hi, I've just seen 10 time 103 x 26 (Bid/Offer) size go through from 3891.25 down to 3889 on footprint but no 103 hitting into the bids (volume size greater than 50) in T&S this would be one trader doing the same exact size so not combined yet this not printed in T&S? Thanks. Stephen |
[2022-07-19 08:29:53] |
Sierra_Chart Engineering - Posts: 18789 |
Those trades must not have been entered as single 103 quantity trades. They must have been broken into multiple orders that added up to 103. Look at the actual trades following these instructions: Time and Sales Window: Viewing Time and Sales on a Spreadsheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-19 11:55:02] |
Stav - Posts: 104 |
Hi, Okay, thanks. Stephen |
