Date/Time: Sun, 16 Mar 2025 03:00:48 +0000
Chart Drawing Time shows zero
View Count: 483
[2022-07-18 07:17:24] |
User311344 - Posts: 142 |
Chart Drawing Time [ms] shows zero all the time. Draws per second and Calculations per second are being updated corretly. Is there any change in how I should look at it? I was used to check miliseconds. |
[2022-07-18 09:00:24] |
We will check on this but it is possible that the time is under 1 ms.
[2022-07-18 12:36:30] |
Thanks. The chart is rather calc-intensive and I was getting ca. 15-25ms before. But you report more and more performance improvements so maybe it got radically lower :-) |
[2022-07-18 12:58:11] |
Are you using OpenGL?
[2022-07-18 15:50:28] |
No, Im not.
[2022-08-09 14:07:48] |
Build 2422 and still zero. Any ETA on that? Included some figures. If I understand that correctly Drawing time shouldnt be zero with those draws/calculations per second |
