Date/Time: Fri, 25 Sep 2026 13:13:23 +0000
Extension Line Failure - Color bar based on alert condition for BVAP and AVAP
View Count: 1158
[2022-07-17 13:54:25]
kennedpa - Posts: 16
Why do extension lines not populate when condition is true?
They are turned on, I have tried every iteration of available extension, and various draw styles.
Alert condition is set as below (each condition is a separate study, and this is being used on a volume chart. I have tried time, range, volume, and footprint charts.
=BVAP(ID0.SG4, 0)>500
=AVAP(...............
Color bar alert populates properly just without extension lines.
Is there a work around that's not time consuming for you to suggest?
I have also tried price based alerts, as an example =(ID0.SG2-ID0.SG3=0.25) which generates proper alerts without extension lines.
Thank you.
Date Time Of Last Edit: 2022-07-17 13:59:24
[2022-07-17 14:39:29]
User431178 - Posts: 907
You need to set output condition when true & input data to appropriate values.
Color Bar Based on Alert Condition
Color Bar Based on Alert Condition: Draw Extension Lines at Color Bar Value
Example attached.
attachmentAlertLineExample.Cht - Attached On 2022-07-17 14:39:25 UTC - Size: 3.43 KB - 452 views
[2022-07-17 14:48:40]
I wasn't looking at the context of those as an assignment. Thank you so much. It's fixed.
