Date/Time: Tue, 22 Apr 2025 23:05:29 +0000
Convert .CHT file
View Count: 1768
[2022-07-16 19:28:31] |
TraderSC2212 - Posts: 1 |
I am getting an error message saying to contact Sierra to convert my chart file. Please can I have the updated version.
[2022-07-16 22:48:02] |
Sierra_Chart Engineering - Posts: 19305 |
Converted Chartbook is attached.
[2022-08-17 16:21:43] |
User911964 - Posts: 7 |
hi can u convert this too pls
[2022-08-17 16:25:12] |
John - SC Support - Posts: 39428 |
User911964: Attached is the updated chartbook. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-07 17:27:29] |
Tomas.R - Posts: 9 |
Hello, I'd be gratefull if someone from Sierra Support could translate attached .cht to the latest format. Thank you in advance, Tomas. Date Time Of Last Edit: 2022-09-07 17:35:32
![]() Attachment Deleted. |
[2022-09-08 00:52:16] |
[2024-12-20 13:07:38] |
User698326 - Posts: 1 |
Hello can this file please be converted to the latest version , thank you
Private File |
[2024-12-20 15:32:20] |
Follow the instructions at the following link: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
