Date/Time: Sat, 15 Mar 2025 07:48:36 +0000
Custom TPO Session Start + End Times
View Count: 475
[2022-07-16 13:57:49] |
Rathinp - Posts: 3 |
Hi, Is it possible to update the custom session start + end times - so that each session does not need to be the start of the last end time. E.G. 0100 - 0700 0800 - 1200 1500 - 2100 Cheers |
[2022-07-16 15:27:47] |
No this is not something we would support. There are complications associated with this.
