Date/Time: Sat, 15 Mar 2025 07:51:03 +0000
Subgraph layer order
View Count: 539
[2022-07-15 19:18:06] |
BenjFlame - Posts: 335 |
Hi, If I need to have a subgraph (from ASCIL) drawn on top of another subgraph within the same study, what should I do? What controls the subgraph order? |
[2022-07-15 21:29:36] |
John - SC Support - Posts: 38678 |
The subgraphs are drawn in order from lowest number to highest (SG1, SG2, etc.). So whichever you want to be on top, needs to be the higher numbered subgraph.
[2022-07-18 17:05:32] |
Yes that is the draw order and that cannot be changed. Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-18 17:05:43
