Date/Time: Sat, 15 Mar 2025 03:47:22 +0000
Trial
View Count: 378
[2022-07-15 16:26:58] |
MH trader - Posts: 1 |
Comment accéder à mon compte gratuit ?
[2022-07-15 16:51:54] |
John - SC Support - Posts: 38678 |
We see that you have activated your free trial, so you are all set. If you have not already downloaded the software, then follow the instructions starting at the following link: Sierra Chart Setup Instructions 1 Once you get the software setup, then follow through these instructions to get started using the software: Getting Started, Opening Charts and Basic Trading: Open A Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
