Date/Time: Sat, 15 Mar 2025 03:54:31 +0000
converting cht file
View Count: 523
[2022-07-15 13:23:14] |
qiw4u23oi4u234 - Posts: 34 |
Hi, I have a few .Cht and .cht files I saved from sierrachart long time ago. When I tried to copy and paste the cht files into data folder and open it from the app, it says Reading it says The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. Can you please help? |
[2022-07-15 13:24:17] |
Attached them here and we will convert them. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-15 13:39:37] |
Thanks!
Date Time Of Last Edit: 2022-07-15 13:40:32
[2022-07-15 15:40:55] |
John - SC Support - Posts: 38678 |
Attached are the updated chartbooks.
