Date/Time: Tue, 26 Nov 2024 11:23:28 +0000
Trading Chart DOM
View Count: 1008
[2014-05-07 19:10:39] |
gmorgan111 - Posts: 121 |
I have the Trading Chart DOM turned on on my NQM4 chart. For some reason the columns under the Buy and Sell are blank. There is no depth showing under the buy and sell. I have tried adjusting the settings and graphics but I still cannont get the depth at various prices around the current price to show. Can you tell what I need to do. Thanks |
[2014-05-07 20:41:20] |
You need to configure the Trade DOM columns as explained here to include the Bid and Ask Sizes: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
