Date/Time: Sat, 15 Mar 2025 07:53:29 +0000
Bars scroll back and bars periods
View Count: 424
[2022-07-15 08:38:56] |
Mustang77 - Posts: 122 |
Hi I have a 3 questions please 1- let's i scroll back the chart to few months back, for example to january 2022, is there an option on Sierra where you click and it brings back the chart to today's date? instead of scrolling back again.( for example on tradingview we right click on the chart and click on "reset chart" ) 2- let's say i want to see on the chart, bars from a certain date to today's date, for example from 1 march to today, what is the quickest way of doing that? instead of scrolling back ...is there a setting where i can enter the date range and the chart will show bars for that date range? 3- same as question 2 but instead of todays date, i want another date, so for example i want to see the bars from 01 march to 01 april. Thanks in advance |
[2022-07-15 08:54:43] |
User907968 - Posts: 838 |
Any of these options - 1) Chart -> Goto End of Chart 2) Press END (or whatever keyboard shortcut you have set for menu item above) 3) Add item 'Goto End of Chart' command to Chart Shortcut Menu, then use it that way (Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu)) 2- let's say i want to see on the chart, bars from a certain date to today's date, for example from 1 march to today, what is the quickest way of doing that? instead of scrolling back ...is there a setting where i can enter the date range and the chart will show bars for that date range?
Does not 100% satify your request, as you can only choose the begin date, but - 1) Chart -> Goto Date-Time 2) Add item 'Goto Date-Time' command to Chart Shortcut Menu, then use it that way (Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu)) 3- same as question 2 but instead of todays date, i want another date, so for example i want to see the bars from 01 march to 01 april.
Don't think this is possible, but I am happy to learn otherwise.
[2022-07-15 15:24:55] |
John - SC Support - Posts: 38678 |
2, 3) Another way you can do this is to use the Date Range option in Chart >> Chart Settings >> Data Limiting by setting Load Data Limiting Method to Use Date Range and then entering the appropriate dates below. Refer to the following: Chart Settings: Load Data Limiting Method (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-22 11:57:59] |
Hi John Thank you very much |
