Date/Time: Sat, 15 Mar 2025 03:47:21 +0000
[Programming Help] - Can we use c++ vector to replace subgraph array?
View Count: 642
[2022-07-15 07:48:36]
User395175 - Posts: 90
Hi, when using sc study function, can I use c++ vector to replace the output subgraph array in the function? I just need the vector to hold my study value, not draw it on chart.
And what the nature of subgraph array, is it also a c++ vector?
[2022-07-15 12:37:59]
No you cannot use a vector like this. We do not know how this would be technically possible. Sierra Chart subgraph arrays are not C++ STL vectors.
[2022-07-15 15:13:28]
Can you increase the number of subgraph we can use in one study to over 100 at next release? Or is there a way for me to define a similar c++ array in sc study to replace the output subgraph array?
