Date/Time: Sun, 20 Sep 2026 23:35:31 +0000
SC Historical Intraday Data not updating anymore
View Count: 750
[2022-07-14 18:21:25]
User197029 - Posts: 67
Hi! As of a few hours my charts are not updating with historical intraday data anymore. This happens only with my SC connection instace datafeed, my other instances with Interactive Brokers are working and updating fine, so I can exclude any network issues. I have updated SC to Version 2416 but not helping. All charts are stuck with the yellow bar "Waiting to download historical data".
Found this message in the log but as I said other instances are working fine.
HD Request # 36 | Downloading Historical Daily chart data for GBPJPY. Starting date: 2022-07-12. Service: fxcm | 2022-07-14 14:09:26.124
HD Request # 36 | Using server: ds4.sierracharts.com port 10150 | 2022-07-14 14:09:26.124
Socket (1) | Creating socket. | 2022-07-14 14:09:26.124
Socket (1) | New receive buffer size: 5242880 | 2022-07-14 14:09:26.124
Socket (1) | Connecting to IP: 192.81.56.146. | 2022-07-14 14:09:26.124
DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-14 14:09:26.490
DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-07-14 14:09:26.490
DTC Client socket (4) | Closed. | 2022-07-14 14:09:26.490
Socket (2) | Socket gracefully closed by remote side. | 2022-07-14 14:09:29.121
Socket (2) | Closed. | 2022-07-14 14:09:29.121
Please help.
[2022-07-14 18:49:00]
John - SC Support - Posts: 47939
Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
[2022-07-14 19:25:03]
Hi John, thanks for your reply, but tbh I dont think there is an issue with the firewall, etc. I have also disabled it and same thing keeps happening.
What is strange is that my SC instances with Interactive Brokers work fine and update normally. There has also been NO CHANGE whatsoever on my side (no windows updates etc) in the last few hours, it just stopped working on the SC feed.
I found also that at the moment of disconnecting and then reconnecting to the datafeed the values in the DOM move so for a few secs there seems to be data but then charts dont update and DOM stops.
Could you check my log file - maybe you can help and discover something there?
Thanks!!
Software version: 2416 64-bit | 2022-07-14 15:16:20.064
Primary Thread ID: 13444 | 2022-07-14 15:16:20.064
Usage end date: 2022-12-01 | 2022-07-14 15:16:20.064
Enabled for: Advanced Features 2. | 2022-07-14 15:16:20.064
Enabled for: Sierra Chart Historical Data Service. | 2022-07-14 15:16:20.064
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-07-14 15:16:20.064
Enabled for: Delayed Denali Exchange Data Feed. | 2022-07-14 15:16:20.064
Enabled for exchange2: CME (Trading Account Required) | 2022-07-14 15:16:20.064
Enabled for exchange2: CBOT (Trading Account Required) | 2022-07-14 15:16:20.064
Enabled for exchange2: COMEX (Trading Account Required) | 2022-07-14 15:16:20.064
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-07-14 15:16:20.064
Enabled for exchange2: EUREX EOBI | 2022-07-14 15:16:20.064
Enabled for exchange2: fairx_exchange.data | 2022-07-14 15:16:20.064
Allow Support for Sierra Chart Data Feeds is disabled. | 2022-07-14 15:16:20.064
Current selected Data/Trading service: SC Data - All Services | 2022-07-14 15:16:20.064
Custom symbol settings values: enabled | 2022-07-14 15:16:20.064
Chart Update Interval: 500 | 2022-07-14 15:16:20.064
Intraday Data Storage Time Unit: 4 | 2022-07-14 15:16:20.064
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-07-14 15:16:20.064
2022-07-14 19:16:20 Local computer time in UTC | 2022-07-14 15:16:20.064
2022-07-14 15:16:20 Local computer time in SC Time Zone | 2022-07-14 15:16:20.064
2022-07-14 18:27:09 Server time in UTC | 2022-07-14 15:16:20.064
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-07-14 15:16:20.064
Program path: D:\SierraChart - FX only\ | 2022-07-14 15:16:20.064
Data Files path: D:\SierraChart - FX only\Data\ | 2022-07-14 15:16:20.064
OS Version Number: 10.0 | 2022-07-14 15:16:20.064
Locale Setting: C | 2022-07-14 15:16:20.064
DLLs: sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_2273_64.dll, sst_FreeBundle_64.dll, sst_volume_dots.dll, sst_volume_dots_2151.dll, sst_volume_dots_2151_64.dll, sst_volume_dots_64.dll, TicinoMathV2.0.dll, TicinoMathV2.0_64.dll, TicinoMathV3.0.dll, TicinoMathV3.0_2151.dll, TicinoMathV3.0_2151_64.dll, TicinoMathV3.0_64.dll, TicinoMath_Scanner.dll, TicinoMath_Scanner_2151.dll, TicinoMath_Scanner_2151_64.dll, TicinoMath_Scanner_64.dll, TicinoSuite_64.dll, UserContributedStudies.dll | 2022-07-14 15:16:20.064
Allowed protected custom studies: SST_FreeBundle, TicinoMathScanner DLL, TicinoMathV2.0.DLL, TicinoMathV3.0.DLL, TicinoSuite | 2022-07-14 15:16:20.064
Crash reporter started: true | 2022-07-14 15:16:20.064
SC Data - All Services | Connected to server complete. | 2022-07-14 15:16:25.262
Triggering next historical data download in queue. | 2022-07-14 15:16:25.263
Using symbol data fast lookup vector | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: USD-X. ID: 1 Service code: fxstatscalc | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: USD-X. ID: 1 | 2022-07-14 15:16:25.263
Added historical Intraday data request for USD-X to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol USD-X is set to download 'Pending'. | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: AUD-X. ID: 2 Service code: fxstatscalc | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: AUD-X. ID: 2 | 2022-07-14 15:16:25.263
Added historical Intraday data request for AUD-X to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol AUD-X is set to download 'Pending'. | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: NZD-X. ID: 3 Service code: fxstatscalc | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: NZD-X. ID: 3 | 2022-07-14 15:16:25.263
Added historical Intraday data request for NZD-X to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol NZD-X is set to download 'Pending'. | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: EUR-X. ID: 4 Service code: fxstatscalc | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: EUR-X. ID: 4 | 2022-07-14 15:16:25.263
Added historical Intraday data request for EUR-X to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol EUR-X is set to download 'Pending'. | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: CAD-X. ID: 5 Service code: fxstatscalc | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: CAD-X. ID: 5 | 2022-07-14 15:16:25.263
Added historical Intraday data request for CAD-X to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol CAD-X is set to download 'Pending'. | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: GBP-X. ID: 6 Service code: fxstatscalc | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: GBP-X. ID: 6 | 2022-07-14 15:16:25.263
Added historical Intraday data request for GBP-X to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol GBP-X is set to download 'Pending'. | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: JPY-X. ID: 7 Service code: fxstatscalc | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: JPY-X. ID: 7 | 2022-07-14 15:16:25.263
Added historical Intraday data request for JPY-X to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol JPY-X is set to download 'Pending'. | 2022-07-14 15:16:25.263
Using Bid/Ask average for last trade price for XAUUSD | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 8 Service code: fxcm | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 8 | 2022-07-14 15:16:25.263
Added historical Intraday data request for XAUUSD to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-07-14 15:16:25.263
Using Bid/Ask average for last trade price for AUDCAD | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDCAD. ID: 9 Service code: fxcm | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: AUDCAD. ID: 9 | 2022-07-14 15:16:25.263
Added historical Intraday data request for AUDCAD to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol AUDCAD is set to download 'Pending'. | 2022-07-14 15:16:25.263
Using Bid/Ask average for last trade price for AUDCHF | 2022-07-14 15:16:25.263
DTC Client socket (1) | Creating socket. | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDCHF. ID: 10 Service code: fxcm | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: AUDCHF. ID: 10 | 2022-07-14 15:16:25.263
Added historical Intraday data request for AUDCHF to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol AUDCHF is set to download 'Pending'. | 2022-07-14 15:16:25.263
Using Bid/Ask average for last trade price for AUDJPY | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDJPY. ID: 11 Service code: fxcm | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: AUDJPY. ID: 11 | 2022-07-14 15:16:25.263
Added historical Intraday data request for AUDJPY to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2022-07-14 15:16:25.263
Using Bid/Ask average for last trade price for AUDNZD | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDNZD. ID: 12 Service code: fxcm | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: AUDNZD. ID: 12 | 2022-07-14 15:16:25.263
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-07-14 15:16:25.263
Added historical Intraday data request for AUDNZD to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol AUDNZD is set to download 'Pending'. | 2022-07-14 15:16:25.263
Using Bid/Ask average for last trade price for AUDUSD | 2022-07-14 15:16:25.263
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 13 Service code: fxcm | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 13 | 2022-07-14 15:16:25.263
Added historical Intraday data request for AUDUSD to the queue. | 2022-07-14 15:16:25.263
Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2022-07-14 15:16:25.263
Using Bid/Ask average for last trade price for CADCHF | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Starting real-time market data updates for: CADCHF. ID: 14 Service code: fxcm | 2022-07-14 15:16:25.263
SC DTC Data with Market Depth | Requesting security definition data for: CADCHF. ID: 14 | 2022-07-14 15:16:25.263
Added historical Intraday data request for CADCHF to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol CADCHF is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for CADJPY | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: CADJPY. ID: 15 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: CADJPY. ID: 15 | 2022-07-14 15:16:25.264
Added historical Intraday data request for CADJPY to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol CADJPY is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for CHFJPY | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: CHFJPY. ID: 16 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: CHFJPY. ID: 16 | 2022-07-14 15:16:25.264
Added historical Intraday data request for CHFJPY to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol CHFJPY is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for EURAUD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: EURAUD. ID: 17 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: EURAUD. ID: 17 | 2022-07-14 15:16:25.264
Added historical Intraday data request for EURAUD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol EURAUD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for EURCAD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: EURCAD. ID: 18 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: EURCAD. ID: 18 | 2022-07-14 15:16:25.264
Added historical Intraday data request for EURCAD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol EURCAD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for EURCHF | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: EURCHF. ID: 19 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: EURCHF. ID: 19 | 2022-07-14 15:16:25.264
Added historical Intraday data request for EURCHF to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol EURCHF is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for EURGBP | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: EURGBP. ID: 20 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: EURGBP. ID: 20 | 2022-07-14 15:16:25.264
Added historical Intraday data request for EURGBP to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol EURGBP is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for EURJPY | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: EURJPY. ID: 21 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: EURJPY. ID: 21 | 2022-07-14 15:16:25.264
Added historical Intraday data request for EURJPY to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for EURNZD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: EURNZD. ID: 22 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: EURNZD. ID: 22 | 2022-07-14 15:16:25.264
Added historical Intraday data request for EURNZD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol EURNZD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for EURUSD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 23 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 23 | 2022-07-14 15:16:25.264
Added historical Intraday data request for EURUSD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for GBPAUD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPAUD. ID: 24 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: GBPAUD. ID: 24 | 2022-07-14 15:16:25.264
Added historical Intraday data request for GBPAUD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol GBPAUD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for GBPCAD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPCAD. ID: 25 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: GBPCAD. ID: 25 | 2022-07-14 15:16:25.264
Added historical Intraday data request for GBPCAD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol GBPCAD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for GBPCHF | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPCHF. ID: 26 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: GBPCHF. ID: 26 | 2022-07-14 15:16:25.264
Added historical Intraday data request for GBPCHF to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol GBPCHF is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for GBPJPY | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPJPY. ID: 27 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: GBPJPY. ID: 27 | 2022-07-14 15:16:25.264
Added historical Intraday data request for GBPJPY to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol GBPJPY is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for GBPNZD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPNZD. ID: 28 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: GBPNZD. ID: 28 | 2022-07-14 15:16:25.264
Added historical Intraday data request for GBPNZD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol GBPNZD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for GBPUSD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 29 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 29 | 2022-07-14 15:16:25.264
Added historical Intraday data request for GBPUSD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for NZDCAD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: NZDCAD. ID: 30 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: NZDCAD. ID: 30 | 2022-07-14 15:16:25.264
Added historical Intraday data request for NZDCAD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol NZDCAD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for NZDCHF | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: NZDCHF. ID: 31 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: NZDCHF. ID: 31 | 2022-07-14 15:16:25.264
Added historical Intraday data request for NZDCHF to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol NZDCHF is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for NZDJPY | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: NZDJPY. ID: 32 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: NZDJPY. ID: 32 | 2022-07-14 15:16:25.264
Added historical Intraday data request for NZDJPY to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol NZDJPY is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for NZDUSD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: NZDUSD. ID: 33 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: NZDUSD. ID: 33 | 2022-07-14 15:16:25.264
Added historical Intraday data request for NZDUSD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol NZDUSD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for USDCAD | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: USDCAD. ID: 34 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: USDCAD. ID: 34 | 2022-07-14 15:16:25.264
Added historical Intraday data request for USDCAD to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol USDCAD is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for USDCHF | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: USDCHF. ID: 35 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: USDCHF. ID: 35 | 2022-07-14 15:16:25.264
Added historical Intraday data request for USDCHF to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol USDCHF is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for USDJPY | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: USDJPY. ID: 36 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: USDJPY. ID: 36 | 2022-07-14 15:16:25.264
Added historical Intraday data request for USDJPY to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol USDJPY is set to download 'Pending'. | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: USDX. ID: 37 Service code: fxstatscalc | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: USDX. ID: 37 | 2022-07-14 15:16:25.264
Added historical Intraday data request for USDX to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol USDX is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for USDTRY | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: USDTRY. ID: 38 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: USDTRY. ID: 38 | 2022-07-14 15:16:25.264
Added historical Intraday data request for USDTRY to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol USDTRY is set to download 'Pending'. | 2022-07-14 15:16:25.264
Using Bid/Ask average for last trade price for EURTRY | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Starting real-time market data updates for: EURTRY. ID: 39 Service code: fxcm | 2022-07-14 15:16:25.264
SC DTC Data with Market Depth | Requesting security definition data for: EURTRY. ID: 39 | 2022-07-14 15:16:25.264
Added historical Intraday data request for EURTRY to the queue. | 2022-07-14 15:16:25.264
Intraday data recording state for symbol EURTRY is set to download 'Pending'. | 2022-07-14 15:16:25.264
SC Data - All Services | Starting real-time market data updates for: ^USDDKK. ID: 40 | 2022-07-14 15:16:25.264
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ^USDDKK | 2022-07-14 15:16:25.264
SC Data - All Services | Requesting security definition data for: ^USDDKK. ID: 40 | 2022-07-14 15:16:25.264
No historical data client is currently set to download historical Intraday data for ^USDDKK. | 2022-07-14 15:16:25.264
Real-time Intraday chart data file updates started for ^USDDKK | 2022-07-14 15:16:25.264
Opened cached Intraday file: D:\SierraChart - FX only\Data\^USDDKK.scid. Thread ID: 13444 | 2022-07-14 15:16:25.264
Intraday chart data file opened for ^USDDKK | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. USDCHF | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. EURGBP | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. AUDJPY | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. GBPAUD | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. AUDNZD | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. GBPCHF | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. NZDCHF | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. CADJPY | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. CADCHF | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. EURNZD | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. GBPJPY | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. GBPNZD | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. CHFJPY | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. AUDCAD | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. GBPCAD | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. EURCAD | 2022-07-14 15:16:25.264
Subscribing to symbol for symbol alert. GBPAUD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. EURCAD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. AUDCAD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. AUDCHF | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. GBPCAD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. GBPJPY | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. GBPNZD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. AUDUSD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. EURCHF | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. NZDCAD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. EURUSD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. GBPCHF | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. AUDJPY | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. EURAUD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. USDCHF | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. AUDNZD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. CADJPY | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. GBPUSD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. NZDUSD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. EURNZD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. USDJPY | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. CHFJPY | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. USDCAD | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. CADCHF | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. EURJPY | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. NZDCHF | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. NZDJPY | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. EURGBP | 2022-07-14 15:16:25.265
Subscribing to symbol for symbol alert. XAUUSD | 2022-07-14 15:16:25.265
No download requests in the queue to start downloads for. | 2022-07-14 15:16:25.325
Delaying start of download for USD-X. | 2022-07-14 15:16:25.325
SC DTC Data with Market Depth | Starting real-time market data updates for: CHF-X. ID: 41 Service code: fxstatscalc | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Requesting security definition data for: CHF-X. ID: 41 | 2022-07-14 15:16:25.409
Mapping 6RU22-CME to 6RU22. Service code: cme | 2022-07-14 15:16:25.409
SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6RU22-CME (6RU22). ID: 42 Service code: cme | 2022-07-14 15:16:25.409
SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-07-14 15:16:25.409
SC DTC Delayed Exchange Data | Requesting security definition data for: 6RU22-CME (6RU22). ID: 42 | 2022-07-14 15:16:25.409
SC Data - All Services | Starting real-time market data updates for: ^USDPLN. ID: 43 | 2022-07-14 15:16:25.409
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ^USDPLN | 2022-07-14 15:16:25.409
SC Data - All Services | Requesting security definition data for: ^USDPLN. ID: 43 | 2022-07-14 15:16:25.409
SC Data - All Services | Starting real-time market data updates for: ^EURPLN. ID: 44 | 2022-07-14 15:16:25.409
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ^EURPLN | 2022-07-14 15:16:25.409
SC Data - All Services | Requesting security definition data for: ^EURPLN. ID: 44 | 2022-07-14 15:16:25.409
SC Data - All Services | Starting real-time market data updates for: ^EURCZK. ID: 45 | 2022-07-14 15:16:25.409
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ^EURCZK | 2022-07-14 15:16:25.409
SC Data - All Services | Requesting security definition data for: ^EURCZK. ID: 45 | 2022-07-14 15:16:25.409
SC Data - All Services | Starting real-time market data updates for: ^USDCZK. ID: 46 | 2022-07-14 15:16:25.409
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ^USDCZK | 2022-07-14 15:16:25.409
SC Data - All Services | Requesting security definition data for: ^USDCZK. ID: 46 | 2022-07-14 15:16:25.409
Using Bid/Ask average for last trade price for EURNOK | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Starting real-time market data updates for: EURNOK. ID: 47 Service code: fxcm | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Requesting security definition data for: EURNOK. ID: 47 | 2022-07-14 15:16:25.409
Using Bid/Ask average for last trade price for USDMXN | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Starting real-time market data updates for: USDMXN. ID: 48 Service code: fxcm | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Requesting security definition data for: USDMXN. ID: 48 | 2022-07-14 15:16:25.409
Using Bid/Ask average for last trade price for USDNOK | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Starting real-time market data updates for: USDNOK. ID: 49 Service code: fxcm | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Requesting security definition data for: USDNOK. ID: 49 | 2022-07-14 15:16:25.409
Using Bid/Ask average for last trade price for USDSEK | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Starting real-time market data updates for: USDSEK. ID: 50 Service code: fxcm | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Requesting security definition data for: USDSEK. ID: 50 | 2022-07-14 15:16:25.409
Using Bid/Ask average for last trade price for EURSEK | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Starting real-time market data updates for: EURSEK. ID: 51 Service code: fxcm | 2022-07-14 15:16:25.409
SC DTC Data with Market Depth | Requesting security definition data for: EURSEK. ID: 51 | 2022-07-14 15:16:25.409
DTC Client socket (2) | Creating socket. | 2022-07-14 15:16:25.410
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-07-14 15:16:25.410
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2022-07-14 15:16:25.410
Using Bid/Ask average for last trade price for USDCNH | 2022-07-14 15:16:25.474
SC DTC Data with Market Depth | Starting real-time market data updates for: USDCNH. ID: 52 Service code: fxcm | 2022-07-14 15:16:25.474
SC DTC Data with Market Depth | Requesting security definition data for: USDCNH. ID: 52 | 2022-07-14 15:16:25.474
SC DTC Data with Market Depth | Network connection to server complete. | 2022-07-14 15:16:25.591
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-07-14 15:16:25.591
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:16:25.591
SC Data - All Services | Starting real-time market data updates for: define clearly if 240 is a MUST or not. ID: 53 | 2022-07-14 15:16:26.055
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: define clearly if 240 is a MUST or not | 2022-07-14 15:16:26.055
SC Data - All Services | Requesting security definition data for: define clearly if 240 is a MUST or not. ID: 53 | 2022-07-14 15:16:26.055
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-14 15:16:28.734
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-14 15:16:28.734
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:16:28.734
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-07-14 15:16:28.856
SC DTC Data with Market Depth | Sending logon request message. | 2022-07-14 15:16:28.856
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-14 15:16:29.082
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-14 15:16:29.082
SC DTC Data with Market Depth | Received logon response. | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Successfully connected. | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Trading is not supported. | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUD-X | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDCAD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDCHF | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDJPY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDNZD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CAD-X | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADCHF | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADJPY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHF-X | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHFJPY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EUR-X | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURAUD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCAD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCHF | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURGBP | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURJPY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURNOK | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURNZD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURSEK | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURTRY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBP-X | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPAUD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCAD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCHF | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPJPY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPNZD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: JPY-X | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZD-X | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDCAD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDCHF | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDJPY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDUSD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USD-X | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCAD | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCHF | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCNH | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDJPY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDMXN | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDNOK | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDSEK | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDTRY | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDX | 2022-07-14 15:16:29.793
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-07-14 15:16:29.793
Requesting market depth updates for: CADCHF if supported. | 2022-07-14 15:16:30.268
Separate subscription for market depth updates not supported. CADCHF | 2022-07-14 15:16:30.268
SC DTC Data with Market Depth | Received security definition for symbol AUD-X | 2022-07-14 15:16:30.903
SC DTC Data with Market Depth | Received security definition for symbol AUDCAD | 2022-07-14 15:16:30.903
SC DTC Data with Market Depth | Received security definition for symbol AUDCHF | 2022-07-14 15:16:30.903
SC DTC Data with Market Depth | Received security definition for symbol AUDJPY | 2022-07-14 15:16:30.903
SC DTC Data with Market Depth | Received security definition for symbol AUDNZD | 2022-07-14 15:16:30.903
SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol CAD-X | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol CADCHF | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol CADJPY | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol CHF-X | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol CHFJPY | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EUR-X | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURAUD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURCAD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURCHF | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURGBP | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURJPY | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURNOK | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURNZD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURSEK | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURTRY | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol GBP-X | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol GBPAUD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol GBPCAD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol GBPCHF | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol GBPJPY | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol GBPNZD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol JPY-X | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol NZD-X | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol NZDCAD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol NZDCHF | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol NZDJPY | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol NZDUSD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USD-X | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDCAD | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDCHF | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDCNH | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDJPY | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDMXN | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDNOK | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDSEK | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDTRY | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol USDX | 2022-07-14 15:16:30.904
SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-07-14 15:16:30.904
HD Request # 106 | Downloading Intraday chart data for USD-X to the file USD-X.scid. Service: fxstatscalc | 2022-07-14 15:16:35.274
HD Request # 106 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:16:35.274
HD Request # 106 | Using server: ds4.sierracharts.com port 10149 | 2022-07-14 15:16:35.274
Socket (3) | Creating socket. | 2022-07-14 15:16:35.274
Socket (3) | New receive buffer size: 5242880 | 2022-07-14 15:16:35.274
Socket (3) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:16:35.274
SC DTC Delayed Exchange Data | Received logon response. | 2022-07-14 15:16:36.084
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-14 15:16:36.084
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-14 15:16:36.084
SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-14 15:16:36.084
SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-14 15:16:36.084
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6RU22-CME -> 6RU22 | 2022-07-14 15:16:36.084
SC DTC Delayed Exchange Data | Received security definition for symbol 6RU22-CME | 2022-07-14 15:16:50.529
AUDNZD[M] 1 Day #3 | Reloading chart. | 2022-07-14 15:16:53.778
AUDNZD[M] #1 | Reloading chart. | 2022-07-14 15:16:53.999
AUDNZD[M] 30 Min #8 | Reloading chart. | 2022-07-14 15:16:54.731
AUDNZD[M] 30 Min #5 | Reloading chart. | 2022-07-14 15:16:54.772
AUDNZD[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:16:54.788
AUDNZD[M] 30 Min #2 | Reloading chart. | 2022-07-14 15:16:54.837
Chart #8 has tagged chart #5 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:54.849
AUDNZD[M] 1 Day #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:16:54.873
Chart #3 has tagged chart #12 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:54.874
AUDNZD[M] 1 Day #4 | Reloading chart. | 2022-07-14 15:16:54.907
AUDNZD[M] 30 Min #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:16:54.922
Chart #5 has tagged chart #10 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:54.925
AUDNZD[M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:16:54.939
AUDNZD[M] 5 Min #10 | Reloading chart. | 2022-07-14 15:16:54.996
AUDNZD[M] 1 Day #7 | Reloading chart. | 2022-07-14 15:16:55.035
AUDNZD[M] 5 Min #6 | Reloading chart. | 2022-07-14 15:16:55.102
AUDNZD[M] 5 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:16:55.117
Chart #10 has tagged chart #1 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.121
Chart #10 has tagged chart #2 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.121
Chart #10 has tagged chart #4 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.121
Chart #10 has tagged chart #5 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.121
Chart #10 has tagged chart #6 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.121
Chart #10 has tagged chart #7 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.121
AUDNZD[M] 240 Min #9 | Reloading chart. | 2022-07-14 15:16:55.172
AUDNZD[M] #12 | Reloading chart. | 2022-07-14 15:16:55.218
AUDNZD[M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:16:55.235
Socket (3) | CloseSocket call. | 2022-07-14 15:16:55.265
Socket (3) | Closed. | 2022-07-14 15:16:55.266
HD Request # 106 | Error downloading historical Intraday data for USD-X. Timeout error connecting to server. | 2022-07-14 15:16:55.299
Added historical Intraday data request for USD-X to the queue. | 2022-07-14 15:16:55.299
Triggering next historical data download in queue. | 2022-07-14 15:16:55.299
Historical data download thread signaled to stop. | 2022-07-14 15:16:55.299
HD Request # 106 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for USD-X | 2022-07-14 15:16:55.300
HD Request # 106 | Completion time: 20s. | 2022-07-14 15:16:55.300
HD Request # 107 | Downloading Intraday chart data for USD-X to the file USD-X.scid. Service: fxstatscalc | 2022-07-14 15:16:55.300
HD Request # 107 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:16:55.300
HD Request # 107 | Using server: ds12.sierracharts.com port 10150 | 2022-07-14 15:16:55.300
Socket (3) | Creating socket. | 2022-07-14 15:16:55.300
Socket (3) | New receive buffer size: 5242880 | 2022-07-14 15:16:55.300
Socket (3) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:16:55.300
AUDNZD[M] 1 Day #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:16:55.354
Chart #7 has tagged chart #4 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.355
Chart #7 has tagged chart #9 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.355
Unsubscribed from market depth data for CADCHF | 2022-07-14 15:16:55.438
Requesting market depth updates for: AUDNZD if supported. | 2022-07-14 15:16:55.438
Separate subscription for market depth updates not supported. AUDNZD | 2022-07-14 15:16:55.438
AUDNZD[M] #12 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-07-14 12:01:00. Next Bar Date Time: 2022-07-14 11:59:00. Filename: AUDNZD.scid | 2022-07-14 15:16:55.543
AUDNZD[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.606
AUDNZD[M] 240 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.638
AUDNZD[M] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.755
Circular chart reference detected. Charts: 10, 5. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht. | 2022-07-14 15:16:55.757
AUDNZD[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.795
AUDNZD[M] 1 Day #4 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:16:55.888
HD Request # 107 | Sending historical data logon request message. | 2022-07-14 15:17:08.638
HD Request # 107 | Setting DTC encoding to Binary VLS | 2022-07-14 15:17:44.029
HD Request # 107 | Sending historical data logon request message. | 2022-07-14 15:17:44.029
Socket (3) | CloseSocket call. | 2022-07-14 15:17:44.029
Socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-14 15:17:44.029
HD Request # 107 | Error downloading historical Intraday data for USD-X. Historical data logon error: Unsupported protocol version | 2022-07-14 15:17:44.029
Historical data download thread signaled to stop. | 2022-07-14 15:17:44.029
HD Request # 107 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for USD-X | 2022-07-14 15:17:44.029
HD Request # 107 | Completion time: 49s. | 2022-07-14 15:17:44.029
HD Request # 107 | Intraday data download complete for USD-X. Unique request ID: 382 | 2022-07-14 15:17:44.029
Removing historical data download ID 382. | 2022-07-14 15:17:44.029
Real-time Intraday chart data file updates started for USD-X | 2022-07-14 15:17:44.029
Opened cached Intraday file: D:\SierraChart - FX only\Data\USD-X.scid. Thread ID: 13444 | 2022-07-14 15:17:44.029
Intraday chart data file opened for USD-X | 2022-07-14 15:17:44.029
HD Request # 107 | Enabling Intraday chart updating for symbol. | 2022-07-14 15:17:44.029
Triggering next historical data download in queue. | 2022-07-14 15:17:44.029
HD Request # 108 | Downloading Intraday chart data for AUD-X to the file AUD-X.scid. Service: fxstatscalc | 2022-07-14 15:17:44.029
HD Request # 108 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:17:44.030
HD Request # 108 | Using server: ds4.sierracharts.com port 10149 | 2022-07-14 15:17:44.030
Socket (4) | Creating socket. | 2022-07-14 15:17:44.030
Socket (4) | New receive buffer size: 5242880 | 2022-07-14 15:17:44.030
Socket (4) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:17:44.030
Socket (3) | Write has completed. Shutdown being performed. | 2022-07-14 15:17:45.046
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:17:45.046
HD Request # 108 | Sending historical data logon request message. | 2022-07-14 15:17:57.341
SC DTC Data with Market Depth | There has been no activity on the network socket for 1m 12s. Will reconnect. | 2022-07-14 15:19:05.282
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-07-14 15:19:05.282
DTC Client socket (1) | CloseSocket call. | 2022-07-14 15:19:05.283
DTC Client socket (1) | Max send buffers used during socket life: 4 | 2022-07-14 15:19:05.283
DTC Client socket (1) | Max send buffer size during socket life: 3418 | 2022-07-14 15:19:05.283
DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-14 15:19:05.283
SC DTC Data with Market Depth | Disconnected from the server. | 2022-07-14 15:19:05.283
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-14 15:19:05.283
SC DTC Delayed Exchange Data | There has been no activity on the network socket for 45s. Will reconnect. | 2022-07-14 15:19:05.403
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-14 15:19:05.403
DTC Client socket (2) | CloseSocket call. | 2022-07-14 15:19:05.405
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:19:05.405
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-14 15:19:05.405
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-14 15:19:05.405
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-07-14 15:19:07.282
DTC Client socket (5) | Creating socket. | 2022-07-14 15:19:07.282
DTC Client socket (5) | New receive buffer size: 5242880 | 2022-07-14 15:19:07.282
DTC Client socket (5) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:19:07.282
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-07-14 15:19:07.404
DTC Client socket (6) | Creating socket. | 2022-07-14 15:19:07.406
DTC Client socket (6) | New receive buffer size: 5242880 | 2022-07-14 15:19:07.406
DTC Client socket (6) | Connecting to IP: 216.1.90.130. | 2022-07-14 15:19:07.406
SC DTC Data with Market Depth | Network connection to server complete. | 2022-07-14 15:19:07.607
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-07-14 15:19:07.607
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:19:07.607
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-07-14 15:19:07.958
SC DTC Data with Market Depth | Sending logon request message. | 2022-07-14 15:19:07.958
SC DTC Data with Market Depth | Received logon response. | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Successfully connected. | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Trading is not supported. | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUD-X | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDCAD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDCHF | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDJPY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDNZD. Market Depth data restarted. | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CAD-X | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADCHF | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADJPY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHF-X | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHFJPY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EUR-X | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURAUD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCAD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCHF | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURGBP | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURJPY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURNOK | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURNZD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURSEK | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURTRY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBP-X | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPAUD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCAD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCHF | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPJPY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPNZD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: JPY-X | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZD-X | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDCAD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDCHF | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDJPY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDUSD | 2022-07-14 15:19:08.882
Added historical Intraday data request for USD-X to the queue. | 2022-07-14 15:19:08.882
Intraday data recording state for symbol USD-X is set to download 'Pending'. | 2022-07-14 15:19:08.882
Triggering next historical data download in queue. | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USD-X | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCAD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCHF | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCNH | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDJPY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDMXN | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDNOK | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDSEK | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDTRY | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDX | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-07-14 15:19:08.882
SC DTC Data with Market Depth | Received security definition for symbol AUD-X | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol AUDCAD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol AUDCHF | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol AUDJPY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol AUDNZD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol CAD-X | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol CADCHF | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol CADJPY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol CHF-X | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol CHFJPY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EUR-X | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURAUD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURCAD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURCHF | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURGBP | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURJPY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURNOK | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURNZD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURSEK | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURTRY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol GBP-X | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol GBPAUD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol GBPCAD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol GBPCHF | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol GBPJPY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol GBPNZD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol JPY-X | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol NZD-X | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol NZDCAD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol NZDCHF | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol NZDJPY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol NZDUSD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USD-X | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDCAD | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDCHF | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDCNH | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDJPY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDMXN | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDNOK | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDSEK | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDTRY | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol USDX | 2022-07-14 15:19:09.294
SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-07-14 15:19:09.294
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-14 15:19:10.722
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-14 15:19:10.722
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:19:10.722
HD Request # 108 | Error downloading historical Intraday data for AUD-X. The download timed out. | 2022-07-14 15:19:15.904
Added historical Intraday data request for AUD-X to the queue. | 2022-07-14 15:19:15.904
Triggering next historical data download in queue. | 2022-07-14 15:19:15.904
Historical data download thread signaled to stop. | 2022-07-14 15:19:15.905
Socket (4) | CloseSocket call. | 2022-07-14 15:19:15.905
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:19:15.905
HD Request # 108 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for AUD-X | 2022-07-14 15:19:15.905
HD Request # 108 | Completion time: 1m 31s. | 2022-07-14 15:19:15.905
HD Request # 109 | Downloading Intraday chart data for AUD-X to the file AUD-X.scid. Service: fxstatscalc | 2022-07-14 15:19:15.905
HD Request # 109 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:19:15.905
HD Request # 109 | Using server: ds12.sierracharts.com port 10150 | 2022-07-14 15:19:15.905
Socket (7) | Creating socket. | 2022-07-14 15:19:15.905
Socket (7) | New receive buffer size: 5242880 | 2022-07-14 15:19:15.905
Socket (7) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:19:15.905
HD Request # 109 | Setting DTC encoding to Binary VLS | 2022-07-14 15:19:17.545
HD Request # 109 | Sending historical data logon request message. | 2022-07-14 15:19:17.545
HD Request # 109 | Requesting Intraday data. Start date-time: 2022-07-14 15:08:00. Record interval: 4. Symbol: AUD-X | 2022-07-14 15:19:26.768
SC DTC Delayed Exchange Data | Did not receive Encoding Response from server. Disconnecting. | 2022-07-14 15:19:30.721
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-14 15:19:30.721
DTC Client socket (6) | CloseSocket call. | 2022-07-14 15:19:30.721
DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:19:30.721
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-14 15:19:30.721
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-14 15:19:30.721
SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2022-07-14 15:19:32.722
DTC Client socket (8) | Creating socket. | 2022-07-14 15:19:32.722
DTC Client socket (8) | New receive buffer size: 5242880 | 2022-07-14 15:19:32.722
DTC Client socket (8) | Connecting to IP: 216.1.90.129. | 2022-07-14 15:19:32.722
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-14 15:19:36.041
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-14 15:19:36.041
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:19:36.041
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-14 15:19:39.417
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-14 15:19:39.417
DTC Client socket (1) | Write has completed. Shutdown being performed. | 2022-07-14 15:19:39.769
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:19:39.769
Socket (3) | Socket gracefully closed by remote side. | 2022-07-14 15:19:44.353
Socket (3) | Closed. | 2022-07-14 15:19:44.353
SC DTC Delayed Exchange Data | Received logon response. | 2022-07-14 15:19:48.862
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-14 15:19:48.862
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-14 15:19:48.862
SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-14 15:19:48.862
SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-14 15:19:48.862
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6RU22-CME -> 6RU22 | 2022-07-14 15:19:48.862
SC DTC Delayed Exchange Data | There has been no activity on the network socket for 1m 4s. Will reconnect. | 2022-07-14 15:20:52.716
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-14 15:20:52.716
DTC Client socket (8) | CloseSocket call. | 2022-07-14 15:20:52.717
DTC Client socket (8) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:20:52.717
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-14 15:20:52.717
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-14 15:20:52.717
SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2022-07-14 15:20:54.714
DTC Client socket (3) | Creating socket. | 2022-07-14 15:20:54.715
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-07-14 15:20:54.715
DTC Client socket (3) | Connecting to IP: 204.15.197.13. | 2022-07-14 15:20:54.715
HD Request # 109 | Error downloading historical Intraday data for AUD-X. The download timed out. | 2022-07-14 15:20:57.941
Added historical Intraday data request for AUD-X to the queue. | 2022-07-14 15:20:57.941
Triggering next historical data download in queue. | 2022-07-14 15:20:57.941
Historical data download thread signaled to stop. | 2022-07-14 15:20:57.942
Socket (7) | CloseSocket call. | 2022-07-14 15:20:57.942
Socket (7) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:20:57.942
HD Request # 109 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for AUD-X | 2022-07-14 15:20:57.942
HD Request # 109 | Completion time: 1m 42s. | 2022-07-14 15:20:57.942
HD Request # 110 | Downloading Intraday chart data for AUD-X to the file AUD-X.scid. Service: fxstatscalc | 2022-07-14 15:20:57.942
HD Request # 110 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:20:57.942
HD Request # 110 | Using server: ds4.sierracharts.com port 10149 | 2022-07-14 15:20:57.943
Socket (9) | Creating socket. | 2022-07-14 15:20:57.943
Socket (9) | New receive buffer size: 5242880 | 2022-07-14 15:20:57.943
Socket (9) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:20:57.943
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-14 15:20:58.047
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-14 15:20:58.047
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:20:58.047
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-14 15:20:58.383
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-14 15:20:58.383
SC DTC Delayed Exchange Data | Received logon response. | 2022-07-14 15:20:59.759
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-14 15:20:59.759
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-14 15:20:59.759
SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-14 15:20:59.759
SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-14 15:20:59.759
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6RU22-CME -> 6RU22 | 2022-07-14 15:20:59.759
SC DTC Delayed Exchange Data | Received security definition for symbol 6RU22-CME | 2022-07-14 15:21:00.187
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-07-14 15:21:05.728
DTC Client socket (2) | Closed. | 2022-07-14 15:21:05.728
Socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-14 15:21:17.060
Socket (4) | Socket gracefully closed by remote side. | 2022-07-14 15:21:17.060
Socket (4) | Closed. | 2022-07-14 15:21:17.060
Socket (9) | CloseSocket call. | 2022-07-14 15:21:17.947
Socket (9) | Closed. | 2022-07-14 15:21:17.947
HD Request # 110 | Error downloading historical Intraday data for AUD-X. Timeout error connecting to server. | 2022-07-14 15:21:17.948
Historical data download thread signaled to stop. | 2022-07-14 15:21:17.948
HD Request # 110 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for AUD-X | 2022-07-14 15:21:17.948
HD Request # 110 | Completion time: 20s. | 2022-07-14 15:21:17.948
HD Request # 110 | Intraday data download complete for AUD-X. Unique request ID: 383 | 2022-07-14 15:21:17.948
Removing historical data download ID 383. | 2022-07-14 15:21:17.948
Real-time Intraday chart data file updates started for AUD-X | 2022-07-14 15:21:17.948
Opened cached Intraday file: D:\SierraChart - FX only\Data\AUD-X.scid. Thread ID: 13444 | 2022-07-14 15:21:17.948
Intraday chart data file opened for AUD-X | 2022-07-14 15:21:17.948
HD Request # 110 | Enabling Intraday chart updating for symbol. | 2022-07-14 15:21:17.948
Triggering next historical data download in queue. | 2022-07-14 15:21:17.948
HD Request # 111 | Downloading Intraday chart data for NZD-X to the file NZD-X.scid. Service: fxstatscalc | 2022-07-14 15:21:17.949
HD Request # 111 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:21:17.949
HD Request # 111 | Using server: ds12.sierracharts.com port 10150 | 2022-07-14 15:21:17.949
Socket (2) | Creating socket. | 2022-07-14 15:21:17.949
Socket (2) | New receive buffer size: 5242880 | 2022-07-14 15:21:17.949
Socket (2) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:21:17.949
HD Request # 111 | Setting DTC encoding to Binary VLS | 2022-07-14 15:21:18.621
HD Request # 111 | Sending historical data logon request message. | 2022-07-14 15:21:18.621
HD Request # 111 | Requesting Intraday data. Start date-time: 2022-07-14 15:08:00. Record interval: 4. Symbol: NZD-X | 2022-07-14 15:21:20.327
HD Request # 111 | Decompressing data. | 2022-07-14 15:21:20.647
HD Request # 111 | Receiving Intraday data for NZD-X starting at 2022-07-14 15:08:00.000000 | 2022-07-14 15:21:21.157
Socket (2) | CloseSocket call. | 2022-07-14 15:21:23.089
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:21:23.089
Historical data download thread signaled to stop. | 2022-07-14 15:21:23.091
HD Request # 111 | Timestamp of first Intraday data file record written: 2022-07-14 15:08:00.000000. | 2022-07-14 15:21:23.091
HD Request # 111 | Received 199 Intraday data records from 2022-07-14 15:08:00.000000 to 2022-07-14 15:21:16.000000 (13.3 minutes) and wrote 199 records for NZD-X | 2022-07-14 15:21:23.091
HD Request # 111 | Completion time: 6s. | 2022-07-14 15:21:23.092
HD Request # 111 | Intraday data download complete for NZD-X. Unique request ID: 384 | 2022-07-14 15:21:23.092
Removing historical data download ID 384. | 2022-07-14 15:21:23.092
Real-time Intraday chart data file updates started for NZD-X | 2022-07-14 15:21:23.092
Opened cached Intraday file: D:\SierraChart - FX only\Data\NZD-X.scid. Thread ID: 13444 | 2022-07-14 15:21:23.092
Intraday chart data file opened for NZD-X | 2022-07-14 15:21:23.092
HD Request # 111 | Enabling Intraday chart updating for symbol. | 2022-07-14 15:21:23.092
Triggering next historical data download in queue. | 2022-07-14 15:21:23.092
HD Request # 112 | Downloading Intraday chart data for EUR-X to the file EUR-X.scid. Service: fxstatscalc | 2022-07-14 15:21:23.092
HD Request # 112 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:21:23.092
HD Request # 112 | Using server: ds4.sierracharts.com port 10149 | 2022-07-14 15:21:23.092
Socket (4) | Creating socket. | 2022-07-14 15:21:23.092
Socket (4) | New receive buffer size: 5242880 | 2022-07-14 15:21:23.092
Socket (4) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:21:23.092
Socket (2) | Socket gracefully closed by remote side. | 2022-07-14 15:21:23.419
Socket (2) | Closed. | 2022-07-14 15:21:23.419
HD Request # 112 | Setting DTC encoding to Binary VLS | 2022-07-14 15:21:23.743
HD Request # 112 | Sending historical data logon request message. | 2022-07-14 15:21:23.743
HD Request # 112 | Requesting Intraday data. Start date-time: 2022-07-14 15:08:00. Record interval: 4. Symbol: EUR-X | 2022-07-14 15:21:24.581
HD Request # 112 | Decompressing data. | 2022-07-14 15:21:27.027
HD Request # 112 | Receiving Intraday data for EUR-X starting at 2022-07-14 15:08:00.000000 | 2022-07-14 15:21:27.027
Socket (4) | CloseSocket call. | 2022-07-14 15:21:29.481
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:21:29.481
Historical data download thread signaled to stop. | 2022-07-14 15:21:29.482
HD Request # 112 | Timestamp of first Intraday data file record written: 2022-07-14 15:08:00.000000. | 2022-07-14 15:21:29.482
HD Request # 112 | Received 201 Intraday data records from 2022-07-14 15:08:00.000000 to 2022-07-14 15:21:20.000000 (13.3 minutes) and wrote 201 records for EUR-X | 2022-07-14 15:21:29.482
HD Request # 112 | Completion time: 6s. | 2022-07-14 15:21:29.482
HD Request # 112 | Intraday data download complete for EUR-X. Unique request ID: 385 | 2022-07-14 15:21:29.482
Removing historical data download ID 385. | 2022-07-14 15:21:29.482
Real-time Intraday chart data file updates started for EUR-X | 2022-07-14 15:21:29.482
Opened cached Intraday file: D:\SierraChart - FX only\Data\EUR-X.scid. Thread ID: 13444 | 2022-07-14 15:21:29.482
Intraday chart data file opened for EUR-X | 2022-07-14 15:21:29.482
HD Request # 112 | Enabling Intraday chart updating for symbol. | 2022-07-14 15:21:29.482
Triggering next historical data download in queue. | 2022-07-14 15:21:29.483
HD Request # 113 | Downloading Intraday chart data for CAD-X to the file CAD-X.scid. Service: fxstatscalc | 2022-07-14 15:21:29.483
HD Request # 113 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:21:29.484
HD Request # 113 | Using server: ds12.sierracharts.com port 10150 | 2022-07-14 15:21:29.484
Socket (2) | Creating socket. | 2022-07-14 15:21:29.484
Socket (2) | New receive buffer size: 5242880 | 2022-07-14 15:21:29.484
Socket (2) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:21:29.484
DTC Client socket (6) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-14 15:21:34.881
DTC Client socket (6) | Closed. | 2022-07-14 15:21:34.881
SC DTC Data with Market Depth | There has been no activity on the network socket for 1m 11s. Will reconnect. | 2022-07-14 15:21:47.281
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-07-14 15:21:47.281
DTC Client socket (5) | CloseSocket call. | 2022-07-14 15:21:47.282
DTC Client socket (5) | Max send buffers used during socket life: 4 | 2022-07-14 15:21:47.282
DTC Client socket (5) | Max send buffer size during socket life: 3418 | 2022-07-14 15:21:47.282
SC DTC Data with Market Depth | Disconnected from the server. | 2022-07-14 15:21:47.282
DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-14 15:21:47.282
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-14 15:21:47.282
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2022-07-14 15:21:49.283
DTC Client socket (9) | Creating socket. | 2022-07-14 15:21:49.291
DTC Client socket (9) | New receive buffer size: 5242880 | 2022-07-14 15:21:49.291
DTC Client socket (9) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:21:49.291
Socket (2) | CloseSocket call. | 2022-07-14 15:21:49.483
Socket (2) | Closed. | 2022-07-14 15:21:49.483
HD Request # 113 | Error downloading historical Intraday data for CAD-X. Timeout error connecting to server. | 2022-07-14 15:21:49.483
Added historical Intraday data request for CAD-X to the queue. | 2022-07-14 15:21:49.483
Triggering next historical data download in queue. | 2022-07-14 15:21:49.483
Historical data download thread signaled to stop. | 2022-07-14 15:21:49.483
HD Request # 113 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for CAD-X | 2022-07-14 15:21:49.483
HD Request # 113 | Completion time: 20s. | 2022-07-14 15:21:49.483
HD Request # 114 | Downloading Intraday chart data for CAD-X to the file CAD-X.scid. Service: fxstatscalc | 2022-07-14 15:21:49.484
HD Request # 114 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:21:49.484
HD Request # 114 | Using server: ds4.sierracharts.com port 10149 | 2022-07-14 15:21:49.484
Socket (2) | Creating socket. | 2022-07-14 15:21:49.484
Socket (2) | New receive buffer size: 5242880 | 2022-07-14 15:21:49.484
Socket (2) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:21:49.484
SC DTC Data with Market Depth | Network connection to server complete. | 2022-07-14 15:21:58.631
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-07-14 15:21:58.631
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:21:58.631
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-07-14 15:22:01.989
SC DTC Data with Market Depth | Sending logon request message. | 2022-07-14 15:22:01.989
DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-14 15:22:04.894
DTC Client socket (1) | Closed. | 2022-07-14 15:22:04.895
DTC Client socket (6) | Deleting network socket now after delay. | 2022-07-14 15:22:04.895
Socket (2) | CloseSocket call. | 2022-07-14 15:22:09.490
Socket (2) | Closed. | 2022-07-14 15:22:09.490
HD Request # 114 | Error downloading historical Intraday data for CAD-X. Timeout error connecting to server. | 2022-07-14 15:22:09.491
Added historical Intraday data request for CAD-X to the queue. | 2022-07-14 15:22:09.492
Triggering next historical data download in queue. | 2022-07-14 15:22:09.492
Historical data download thread signaled to stop. | 2022-07-14 15:22:09.492
HD Request # 114 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for CAD-X | 2022-07-14 15:22:09.492
HD Request # 114 | Completion time: 20s. | 2022-07-14 15:22:09.492
HD Request # 115 | Downloading Intraday chart data for CAD-X to the file CAD-X.scid. Service: fxstatscalc | 2022-07-14 15:22:09.492
HD Request # 115 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:22:09.492
HD Request # 115 | Using server: ds12.sierracharts.com port 10150 | 2022-07-14 15:22:09.492
Socket (2) | Creating socket. | 2022-07-14 15:22:09.492
Socket (2) | New receive buffer size: 5242880 | 2022-07-14 15:22:09.493
Socket (2) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:22:09.493
HD Request # 115 | Setting DTC encoding to Binary VLS | 2022-07-14 15:22:13.158
HD Request # 115 | Sending historical data logon request message. | 2022-07-14 15:22:13.159
HD Request # 115 | Requesting Intraday data. Start date-time: 2022-07-14 15:08:00. Record interval: 4. Symbol: CAD-X | 2022-07-14 15:22:13.999
HD Request # 115 | Decompressing data. | 2022-07-14 15:22:14.328
HD Request # 115 | Receiving Intraday data for CAD-X starting at 2022-07-14 15:08:00.000000 | 2022-07-14 15:22:17.356
Socket (2) | CloseSocket call. | 2022-07-14 15:22:17.356
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:22:17.357
Historical data download thread signaled to stop. | 2022-07-14 15:22:17.366
HD Request # 115 | Timestamp of first Intraday data file record written: 2022-07-14 15:08:00.000000. | 2022-07-14 15:22:17.366
HD Request # 115 | Received 213 Intraday data records from 2022-07-14 15:08:00.000000 to 2022-07-14 15:22:12.000000 (14.2 minutes) and wrote 213 records for CAD-X | 2022-07-14 15:22:17.366
HD Request # 115 | Completion time: 8s. | 2022-07-14 15:22:17.366
HD Request # 115 | Intraday data download complete for CAD-X. Unique request ID: 386 | 2022-07-14 15:22:17.366
Removing historical data download ID 386. | 2022-07-14 15:22:17.366
Real-time Intraday chart data file updates started for CAD-X | 2022-07-14 15:22:17.366
Opened cached Intraday file: D:\SierraChart - FX only\Data\CAD-X.scid. Thread ID: 13444 | 2022-07-14 15:22:17.366
Intraday chart data file opened for CAD-X | 2022-07-14 15:22:17.366
HD Request # 115 | Enabling Intraday chart updating for symbol. | 2022-07-14 15:22:17.366
Triggering next historical data download in queue. | 2022-07-14 15:22:17.366
HD Request # 116 | Downloading Intraday chart data for GBP-X to the file GBP-X.scid. Service: fxstatscalc | 2022-07-14 15:22:17.367
HD Request # 116 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:22:17.367
HD Request # 116 | Using server: ds4.sierracharts.com port 10149 | 2022-07-14 15:22:17.367
Socket (6) | Creating socket. | 2022-07-14 15:22:17.367
Socket (6) | New receive buffer size: 5242880 | 2022-07-14 15:22:17.367
Socket (6) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:22:17.367
Socket (2) | Socket gracefully closed by remote side. | 2022-07-14 15:22:17.682
Socket (2) | Closed. | 2022-07-14 15:22:17.682
DTC Client socket (1) | Deleting network socket now after delay. | 2022-07-14 15:22:34.904
GBPUSD[M] 1 Day #3 | Reloading chart. | 2022-07-14 15:22:35.419
GBPUSD[M] 30 Min #2 | Reloading chart. | 2022-07-14 15:22:35.457
GBPUSD[M] #1 | Reloading chart. | 2022-07-14 15:22:35.514
GBPUSD[M] 1 Day #4 | Reloading chart. | 2022-07-14 15:22:35.563
GBPUSD[M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:22:35.584
GBPUSD[M] 5 Min #10 | Reloading chart. | 2022-07-14 15:22:35.674
GBPUSD[M] 1 Day #7 | Reloading chart. | 2022-07-14 15:22:35.736
GBPUSD[M] 5 Min #6 | Reloading chart. | 2022-07-14 15:22:35.810
GBPUSD[M] 5 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:22:35.859
Chart #10 has tagged chart #1 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:35.864
Chart #10 has tagged chart #2 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:35.864
Chart #10 has tagged chart #4 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:35.864
Chart #10 has tagged chart #5 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:35.864
Chart #10 has tagged chart #6 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:35.864
Chart #10 has tagged chart #7 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:35.864
GBPUSD[M] 240 Min #9 | Reloading chart. | 2022-07-14 15:22:35.918
GBPUSD[M] 1 Day #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:22:35.943
Chart #3 has tagged chart #12 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:35.946
GBPUSD[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:22:35.956
GBPUSD[M] #12 | Reloading chart. | 2022-07-14 15:22:36.085
GBPUSD[M] 5 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:22:36.106
GBPUSD[M] 30 Min #8 | Reloading chart. | 2022-07-14 15:22:36.247
GBPUSD[M] 1 Day #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:22:36.261
Chart #7 has tagged chart #4 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.263
Chart #7 has tagged chart #9 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.263
GBPUSD[M] 30 Min #5 | Reloading chart. | 2022-07-14 15:22:36.363
Chart #8 has tagged chart #5 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.385
GBPUSD[M] 1 Day #4 | Reloading chart. | 2022-07-14 15:22:36.426
GBPUSD[M] 30 Min #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-07-14 15:22:36.555
Chart #5 has tagged chart #10 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.560
GBPUSD[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.838
Chart #10 has tagged chart #1 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.841
Chart #10 has tagged chart #4 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.841
Circular chart reference detected. Charts: 5, 10. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht. | 2022-07-14 15:22:36.841
Chart #10 has tagged chart #6 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.841
Chart #10 has tagged chart #7 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.841
GBPUSD[M] 1 Day #7 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.842
Chart #7 has tagged chart #12 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.843
Chart #7 has tagged chart #4 for full recalculation. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.843
GBPUSD[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.865
GBPUSD[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.930
GBPUSD[M] 240 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.936
GBPUSD[M] 1 Day #4 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.951
GBPUSD[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:36.966
GBPUSD[M] #12 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY FX TRACKER V4 05-21.Cht | 2022-07-14 15:22:37.034
Socket (6) | CloseSocket call. | 2022-07-14 15:22:37.358
Socket (6) | Closed. | 2022-07-14 15:22:37.358
HD Request # 116 | Error downloading historical Intraday data for GBP-X. Timeout error connecting to server. | 2022-07-14 15:22:37.358
Added historical Intraday data request for GBP-X to the queue. | 2022-07-14 15:22:37.358
Triggering next historical data download in queue. | 2022-07-14 15:22:37.358
Historical data download thread signaled to stop. | 2022-07-14 15:22:37.358
HD Request # 116 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for GBP-X | 2022-07-14 15:22:37.358
HD Request # 116 | Completion time: 20s. | 2022-07-14 15:22:37.358
HD Request # 117 | Downloading Intraday chart data for GBP-X to the file GBP-X.scid. Service: fxstatscalc | 2022-07-14 15:22:37.358
HD Request # 117 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:22:37.358
HD Request # 117 | Using server: ds12.sierracharts.com port 10150 | 2022-07-14 15:22:37.358
Socket (1) | Creating socket. | 2022-07-14 15:22:37.358
Socket (1) | New receive buffer size: 5242880 | 2022-07-14 15:22:37.358
Socket (1) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:22:37.358
HD Request # 117 | Setting DTC encoding to Binary VLS | 2022-07-14 15:22:38.990
HD Request # 117 | Sending historical data logon request message. | 2022-07-14 15:22:38.990
Unsubscribed from market depth data for AUDNZD | 2022-07-14 15:22:40.287
Requesting market depth updates for: GBPUSD if supported. | 2022-07-14 15:22:40.287
Separate subscription for market depth updates not supported. GBPUSD | 2022-07-14 15:22:40.287
HD Request # 117 | Requesting Intraday data. Start date-time: 2022-07-14 15:08:00. Record interval: 4. Symbol: GBP-X | 2022-07-14 15:22:42.135
HD Request # 117 | Decompressing data. | 2022-07-14 15:22:42.455
HD Request # 117 | Receiving Intraday data for GBP-X starting at 2022-07-14 15:08:00.000000 | 2022-07-14 15:22:42.768
Socket (1) | CloseSocket call. | 2022-07-14 15:22:42.769
Socket (1) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:22:42.769
Historical data download thread signaled to stop. | 2022-07-14 15:22:42.780
HD Request # 117 | Timestamp of first Intraday data file record written: 2022-07-14 15:08:00.000000. | 2022-07-14 15:22:42.780
HD Request # 117 | Received 220 Intraday data records from 2022-07-14 15:08:00.000000 to 2022-07-14 15:22:40.000000 (14.7 minutes) and wrote 220 records for GBP-X | 2022-07-14 15:22:42.780
HD Request # 117 | Completion time: 5s. | 2022-07-14 15:22:42.780
HD Request # 117 | Intraday data download complete for GBP-X. Unique request ID: 387 | 2022-07-14 15:22:42.780
Removing historical data download ID 387. | 2022-07-14 15:22:42.780
Real-time Intraday chart data file updates started for GBP-X | 2022-07-14 15:22:42.780
Opened cached Intraday file: D:\SierraChart - FX only\Data\GBP-X.scid. Thread ID: 13444 | 2022-07-14 15:22:42.781
Intraday chart data file opened for GBP-X | 2022-07-14 15:22:42.781
HD Request # 117 | Enabling Intraday chart updating for symbol. | 2022-07-14 15:22:42.781
Triggering next historical data download in queue. | 2022-07-14 15:22:42.781
HD Request # 118 | Downloading Intraday chart data for JPY-X to the file JPY-X.scid. Service: fxstatscalc | 2022-07-14 15:22:42.781
HD Request # 118 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:22:42.781
HD Request # 118 | Using server: ds4.sierracharts.com port 10149 | 2022-07-14 15:22:42.782
Socket (2) | Creating socket. | 2022-07-14 15:22:42.782
Socket (2) | New receive buffer size: 5242880 | 2022-07-14 15:22:42.782
Socket (2) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:22:42.782
Socket (1) | Socket gracefully closed by remote side. | 2022-07-14 15:22:43.088
Socket (1) | Closed. | 2022-07-14 15:22:43.088
HD Request # 118 | Setting DTC encoding to Binary VLS | 2022-07-14 15:22:46.431
HD Request # 118 | Sending historical data logon request message. | 2022-07-14 15:22:46.431
HD Request # 118 | Requesting Intraday data. Start date-time: 2022-07-14 15:08:00. Record interval: 4. Symbol: JPY-X | 2022-07-14 15:22:48.283
HD Request # 118 | Decompressing data. | 2022-07-14 15:22:48.604
HD Request # 118 | Receiving Intraday data for JPY-X starting at 2022-07-14 15:08:00.000000 | 2022-07-14 15:22:48.927
Socket (2) | CloseSocket call. | 2022-07-14 15:22:48.927
Historical data download thread signaled to stop. | 2022-07-14 15:22:48.927
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:22:48.927
HD Request # 118 | Timestamp of first Intraday data file record written: 2022-07-14 15:08:00.000000. | 2022-07-14 15:22:48.928
HD Request # 118 | Received 221 Intraday data records from 2022-07-14 15:08:00.000000 to 2022-07-14 15:22:48.000000 (14.8 minutes) and wrote 221 records for JPY-X | 2022-07-14 15:22:48.928
HD Request # 118 | Completion time: 6s. | 2022-07-14 15:22:48.928
HD Request # 118 | Intraday data download complete for JPY-X. Unique request ID: 388 | 2022-07-14 15:22:48.928
Removing historical data download ID 388. | 2022-07-14 15:22:48.928
Real-time Intraday chart data file updates started for JPY-X | 2022-07-14 15:22:48.928
Opened cached Intraday file: D:\SierraChart - FX only\Data\JPY-X.scid. Thread ID: 13444 | 2022-07-14 15:22:48.928
Intraday chart data file opened for JPY-X | 2022-07-14 15:22:48.928
HD Request # 118 | Enabling Intraday chart updating for symbol. | 2022-07-14 15:22:48.928
Triggering next historical data download in queue. | 2022-07-14 15:22:48.928
HD Request # 119 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-07-14 15:22:48.928
HD Request # 119 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:22:48.928
HD Request # 119 | Using server: ds12.sierracharts.com port 10150 | 2022-07-14 15:22:48.929
Socket (1) | Creating socket. | 2022-07-14 15:22:48.929
Socket (1) | New receive buffer size: 5242880 | 2022-07-14 15:22:48.929
Socket (1) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:22:48.929
Socket (2) | Socket gracefully closed by remote side. | 2022-07-14 15:22:49.252
Socket (2) | Closed. | 2022-07-14 15:22:49.252
DTC Client socket (5) | Timed out waiting for final send. Canceling I/O. | 2022-07-14 15:23:04.908
Socket (7) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-14 15:23:04.908
Socket (7) | Closed. | 2022-07-14 15:23:04.908
DTC Client socket (8) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-07-14 15:23:04.908
DTC Client socket (8) | Closed. | 2022-07-14 15:23:04.908
DTC Client socket (5) | Write has completed. Shutdown being performed. | 2022-07-14 15:23:04.908
DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:23:04.908
DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-07-14 15:23:04.908
DTC Client socket (5) | Closed. | 2022-07-14 15:23:04.908
Socket (1) | CloseSocket call. | 2022-07-14 15:23:08.922
Socket (1) | Closed. | 2022-07-14 15:23:08.922
HD Request # 119 | Error downloading historical Intraday data for XAUUSD. Timeout error connecting to server. | 2022-07-14 15:23:08.933
Added historical Intraday data request for XAUUSD to the queue. | 2022-07-14 15:23:08.933
Triggering next historical data download in queue. | 2022-07-14 15:23:08.933
Historical data download thread signaled to stop. | 2022-07-14 15:23:08.933
HD Request # 119 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XAUUSD | 2022-07-14 15:23:08.933
HD Request # 119 | Completion time: 20s. | 2022-07-14 15:23:08.933
HD Request # 120 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-07-14 15:23:08.934
HD Request # 120 | Download start date-time: 2022-07-14 15:08:00.000000. File last date-time: 2022-07-14 15:08:00.000000 | 2022-07-14 15:23:08.934
HD Request # 120 | Using server: ds4.sierracharts.com port 10149 | 2022-07-14 15:23:08.934
Socket (1) | Creating socket. | 2022-07-14 15:23:08.934
Socket (1) | New receive buffer size: 5242880 | 2022-07-14 15:23:08.934
Socket (1) | Connecting to IP: 192.81.56.146. | 2022-07-14 15:23:08.934
SC DTC Data with Market Depth | There has been no activity on the network socket for 1m 8s. Will reconnect. | 2022-07-14 15:23:09.278
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-07-14 15:23:09.278
DTC Client socket (9) | CloseSocket call. | 2022-07-14 15:23:09.279
DTC Client socket (9) | Shutdown started. Waiting for graceful close. | 2022-07-14 15:23:09.279
SC DTC Data with Market Depth | Disconnected from the server. | 2022-07-14 15:23:09.279
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-14 15:23:09.279
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-07-14 15:23:11.287
DTC Client socket (2) | Creating socket. | 2022-07-14 15:23:11.287
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-07-14 15:23:11.287
DTC Client socket (2) | Connecting to IP: 204.15.197.14. | 2022-07-14 15:23:11.287
SC DTC Data with Market Depth | Network connection to server complete. | 2022-07-14 15:23:11.608
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-07-14 15:23:11.608
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:23:11.608
HD Request # 120 | Setting DTC encoding to Binary VLS | 2022-07-14 15:23:12.435
HD Request # 120 | Sending historical data logon request message. | 2022-07-14 15:23:12.435
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-07-14 15:23:14.789
SC DTC Data with Market Depth | Sending logon request message. | 2022-07-14 15:23:14.789
HD Request # 120 | Requesting Intraday data. Start date-time: 2022-07-14 15:08:00. Record interval: 4. Symbol: XAUUSD | 2022-07-14 15:23:19.332
SC DTC Data with Market Depth | Received logon response. | 2022-07-14 15:23:21.701
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-07-14 15:23:21.701
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-07-14 15:23:21.701
SC DTC Data with Market Depth | Successfully connected. | 2022-07-14 15:23:21.701
SC DTC Data with Market Depth | Trading is not supported. | 2022-07-14 15:23:21.701
Added historical Intraday data request for AUD-X to the queue. | 2022-07-14 15:23:21.701
Intraday data recording state for symbol AUD-X is set to download 'Pending'. | 2022-07-14 15:23:21.701
Triggering next historical data download in queue. | 2022-07-14 15:23:21.701
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUD-X | 2022-07-14 15:23:21.701
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDCAD | 2022-07-14 15:23:21.701
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDCHF | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDJPY | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDNZD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2022-07-14 15:23:21.702
Added historical Intraday data request for CAD-X to the queue. | 2022-07-14 15:23:21.702
Intraday data recording state for symbol CAD-X is set to download 'Pending'. | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CAD-X | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADCHF | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CADJPY | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHF-X | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHFJPY | 2022-07-14 15:23:21.702
Added historical Intraday data request for EUR-X to the queue. | 2022-07-14 15:23:21.702
Intraday data recording state for symbol EUR-X is set to download 'Pending'. | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EUR-X | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURAUD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCAD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURCHF | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURGBP | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURJPY | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURNOK | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURNZD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURSEK | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURTRY | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-07-14 15:23:21.702
Added historical Intraday data request for GBP-X to the queue. | 2022-07-14 15:23:21.702
Intraday data recording state for symbol GBP-X is set to download 'Pending'. | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBP-X | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPAUD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCAD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCHF | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPJPY | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPNZD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD. Market Depth data restarted. | 2022-07-14 15:23:21.702
Added historical Intraday data request for JPY-X to the queue. | 2022-07-14 15:23:21.702
Intraday data recording state for symbol JPY-X is set to download 'Pending'. | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: JPY-X | 2022-07-14 15:23:21.702
Added historical Intraday data request for NZD-X to the queue. | 2022-07-14 15:23:21.702
Intraday data recording state for symbol NZD-X is set to download 'Pending'. | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZD-X | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDCAD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDCHF | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDJPY | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZDUSD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USD-X | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCAD | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCHF | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCNH | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDJPY | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDMXN | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDNOK | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDSEK | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDTRY | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDX | 2022-07-14 15:23:21.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-07-14 15:23:21.702
Socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-07-14 15:23:32.843
Socket (4) | Socket gracefully closed by remote side. | 2022-07-14 15:23:32.843
Socket (4) | Closed. | 2022-07-14 15:23:32.843
Socket (7) | Deleting network socket now after delay. | 2022-07-14 15:23:34.914
DTC Client socket (8) | Deleting network socket now after delay. | 2022-07-14 15:23:34.914
HD Request # 120 | Decompressing data. | 2022-07-14 15:23:39.376
HD Request # 120 | Receiving Intraday data for XAUUSD starting at 2022-07-14 15:08:00.196000 | 2022-07-14 15:23:39.376
SC DTC Delayed Exchange Data | There has been no activity on the network socket for 1m 13s. Will reconnect. | 2022-07-14 15:24:14.720
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2022-07-14 15:24:14.720
DTC Client socket (3) | CloseSocket call. | 2022-07-14 15:24:14.721
DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-07-14 15:24:14.721
SC DTC Delayed Exchange Data | Disconnected from the server. | 2022-07-14 15:24:14.721
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2022-07-14 15:24:14.721
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2022-07-14 15:24:16.728
DTC Client socket (4) | Creating socket. | 2022-07-14 15:24:16.729
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-07-14 15:24:16.729
DTC Client socket (4) | Connecting to IP: 216.1.90.130. | 2022-07-14 15:24:16.729
SC DTC Delayed Exchange Data | Network connection to server complete. | 2022-07-14 15:24:17.103
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2022-07-14 15:24:17.103
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2022-07-14 15:24:17.103
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2022-07-14 15:24:17.430
SC DTC Delayed Exchange Data | Sending logon request message. | 2022-07-14 15:24:17.430
SC DTC Delayed Exchange Data | Received logon response. | 2022-07-14 15:24:18.758
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2022-07-14 15:24:18.758
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2022-07-14 15:24:18.758
SC DTC Delayed Exchange Data | Successfully connected. | 2022-07-14 15:24:18.758
SC DTC Delayed Exchange Data | Trading is not supported. | 2022-07-14 15:24:18.758
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6RU22-CME -> 6RU22 | 2022-07-14 15:24:18.758
SC DTC Delayed Exchange Data | Received security definition for symbol 6RU22-CME | 2022-07-14 15:24:19.151
SC DTC Data with Market Depth | Received security definition for symbol AUD-X | 2022-07-14 15:24:20.614
SC DTC Data with Market Depth | Received security definition for symbol AUDCAD | 2022-07-14 15:24:20.614
SC DTC Data with Market Depth | Received security definition for symbol AUDCHF | 2022-07-14 15:24:20.614
SC DTC Data with Market Depth | Received security definition for symbol AUDJPY | 2022-07-14 15:24:20.614
SC DTC Data with Market Depth | Received security definition for symbol AUDNZD | 2022-07-14 15:24:20.614
SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2022-07-14 15:24:20.614
SC DTC Data with Market Depth | Received security definition for symbol CAD-X | 2022-07-14 15:24:20.614
[2022-07-14 20:46:00]
You definitively have network connectivity issues! That is 110% definitive based upon this log. It is obvious. Especially with lines like this:
SC DTC Data with Market Depth | There has been no activity on the network socket for 1m 12s. Will reconnect. | 2022-07-14 15:19:05.282
This is not a problem on the Sierra Chart server.
Refer to:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
Date Time Of Last Edit: 2022-07-14 20:46:30
