Date/Time: Sat, 15 Mar 2025 03:47:24 +0000
Entry and trade management weird
View Count: 441
[2022-07-14 15:15:53] |
jack cheadle - Posts: 12 |
As you can see in the upload file it shows my entry way off from where it actually is, 0.6793. The activity log and balance sheet are correct, just not the chart or trade windows. I put a buy stop in and price went right past it and ignored it all together. Not sure what the issue is. Everything works fine with my es/mes trades, just not this aus.
![]() Attachment Deleted. |
[2022-07-14 23:01:44] |
We do not understand this. Probably the reason for this is because you are charting the full-size contract but trading the micro contract and you are actually not seeing the price action in the micro contract: I put a buy stop in and price went right past it and ignored it all together.
So do not use that configuration that you are. You must only be charting the micro contract. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-14 23:02:41
