Date/Time: Sat, 15 Mar 2025 03:54:32 +0000
Modification orders
View Count: 617
[2022-07-14 13:54:58]
User613910 - Posts: 46
I have a problem with my order management. When I want to close an order a message appears that I have to confirm and that I can cancel this message trough the M Menu and confirmations "confirm order Modification".... These (Confirm order Modifications) are not enabled so what to do? If it is unabled and still giving this message what to do?? It is very disturbing while trading...
Already thanks for your answer,
Annita
Date Time Of Last Edit: 2022-07-14 14:00:14
[2022-07-14 15:28:22]
John - SC Support - Posts: 38678
First, make sure you have all the necessary confirmation options turned off. You mention closing an order, but then you turned off the notification for "Order Modification". Make sure the option for "Confirm Flatten/Reverse" is also disabled.
You can also disable all order notifications globally using the following setting for Trade >> Chart Trade Settings >> General >> Disable Order Confirmations - Global. Refer to the information here:
Global Trade Settings Windows: Disable Order Confirmations - Global (Global Settings >> Chart Trade Settings >> General >> Confirmations)
Just note that when using the Order Allocation to Trade Accounts feature, you can not turn off the confirmations.
