Date/Time: Sat, 15 Mar 2025 07:51:03 +0000
Connection Error
View Count: 432
[2022-07-14 07:03:42]
User220777 - Posts: 1
Hello, I have been able to confirm the data feed from CQG to Rithmic, now get an error message in Sierra Chart.
I entered the data correctly, but I can't get a connection. My account name is karben.
I contacted AMP support, they referred me to Sierra Chart Support as there is no error found with AMP and Rithmic.
Best Regards
image2022-07-13 09_11_07-Service Connection Error.jpg / V - Attached On 2022-07-14 07:02:16 UTC - Size: 66.87 KB - 120 views
imageSierra Chart 2411 Rithmic Direct - DTC 2022-07-13.jpg / V - Attached On 2022-07-14 07:02:29 UTC - Size: 11.42 KB - 135 views
imageRithmic.png / V - Attached On 2022-07-14 07:02:43 UTC - Size: 85.28 KB - 109 views
[2022-07-14 14:41:39]
John - SC Support - Posts: 38678
Since you are getting a "Permission Denied" error with Rithmic, that means that either your Username or Password for Rithmic on the Data/Trade Service Settings, is incorrect. You will need to ask your broker about this as we do not have any information related to your Rithmic account.
[2022-07-18 17:41:34]
Refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
