Date/Time: Tue, 26 Nov 2024 11:50:27 +0000
Real time updating of historical chart
View Count: 943
[2014-05-07 18:47:43] |
User53601 - Posts: 105 |
I use two copies od Sierra. Both copies use the same daily timeframe chart. However, one does not update the chart during the session - the one connected to broker/Interactive brokers. The other one, connected to IQfeed does updates the chart. I compared the Chart settings, they are the same. Please find attached. I also checked the Advanced setting, please find attached. I read through the Help but did not find the reason behind. Could you please help. Jaro Date Time Of Last Edit: 2014-05-07 18:48:30
Daily IB.png / V - Attached On 2014-05-07 18:47:11 UTC - Size: 64.43 KB - 336 views Daily Chart Advanced settings.png / V - Attached On 2014-05-07 18:47:23 UTC - Size: 52.53 KB - 313 views |
[2014-05-07 19:39:21] |
Refer to help topic 6: Http://www.sierrachart.com/index.php?l=doc/helpdetails6.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-07 19:41:19] |
Actually, the likely solution to this will be to enable Global Settings >> General Settings >> Use Non Chart Data from Remote Instances.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-07 19:41:34
[2014-05-07 20:50:35] |
Yes, that is it: Global Settings >> General Settings >> Use Non Chart Data from Remote Instances. Thank you very much. Jaro |
