Date/Time: Sat, 15 Mar 2025 03:52:10 +0000
[Programming Help] - New update 2204 gui change?
View Count: 719
[2022-07-13 22:15:02] |
JPECO - Posts: 1 |
I just updated to version 2204. I went to Global Settings: General Settings. Instead of the normal interface, I saw black screened boxes as attached. Please let me know how to go back to what I'm used to seeing as attached.
Private File Private File |
[2022-07-14 02:29:12] |
Sawtooth - Posts: 4183 |
There is no option to use the original interface. All Dialog Windows will eventually be converted to the new format. Settings Windows Interface: Working with Sierra Chart Settings Windows |
[2022-07-14 04:32:20] |
These are the new Settings Windows: Settings Windows Interface The colors can be changed. Refer to: Settings Windows Interface: Colors and Font Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-14 06:38:56] |
BenjFlame - Posts: 335 |
New interface is infinitely better. Hope all studies dialogs will be converted to it. The search field is invaluable. Date Time Of Last Edit: 2022-07-14 06:45:59
[2022-07-14 20:44:09] |
Yes the search functionality is very helpful.
[2022-07-14 23:28:55] |
Gary Number 2 - Posts: 131 |
Having search functionality in studies dialogues would be a massive improvement. Also, new trade windows! |
[2022-07-15 00:32:16] |
Yes that is planned.
