Date/Time: Tue, 26 Nov 2024 11:29:19 +0000
no real-time updates from SC real-time feed
View Count: 1005
[2014-05-07 16:32:29] |
jesslinn - Posts: 108 |
Installed 1132 Activated SC real-time feed Activated CME Start SC - set up for IB trading with SC data enabled Find Symbol. - choose ES201406-GLOBEX Chart comes up with [M] indicator and data to the current tick but then there is no subsequent data. If I disconnect and connect data feed then I get data to the current tick again. I attached the log of the session. |
[2014-05-07 16:52:36] |
This is now resolved for your account. Select File >> Disconnect and then File >> Connect to Data Feed. For some reason there was a problem setting the exchange on the backend. We reactivated it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
