Date/Time: Fri, 04 Apr 2025 13:05:55 +0000
wave trend oscillator
View Count: 1296
[2022-07-13 20:20:00]
User411320 - Posts: 312
any way the wave trend oscillator can be put in SC? this is code from Tradeovate.
const predef = require("./tools/predef");
const meta = require("./tools/meta");
const EMA = require("./tools/EMA");
const SMA = require("./tools/SMA");
const typicalPrice = require("./tools/typicalPrice");
const p = require("./tools/plotting");
class waveTrendOscillator {
init() {
this.c1 = EMA(this.props.channelLength);
this.c2 = EMA(this.props.channelLength);
this.a = EMA(this.props.averageLength);
this.s = SMA(this.props.smoothLength);
this.pWt1 = 0.0;
this.pWt2 = 0.0;
this.obIndex = 0;
this.osIndex = 0;
this.crossunderIndex = 0;
this.crossoverIndex = 0;
map(d, i, history) {
const typ = typicalPrice(d);
let esa = this.c1(typ);
let dist = this.c2(Math.abs(typ - esa));
let ci = (typ - esa) / (this.props.cciConstant * dist);
let ci2 = Number.isNaN(ci) ? 0 : ci
let wt1 = this.a(ci2);
let wt2 = this.s(wt1);
const obValue = Math.min(this.props.overbought1, this.props.overbought2)
const osValue = Math.max(this.props.oversold1, this.props.oversold2);
// save index of where ob/os condition occurred
if (this.pWt1 obValue) {
this.obIndex = i;
if (this.pWt1 >= osValue && wt1 < osValue) {
this.osIndex = i;
// crossunder from overbought
let sell = false;
let buy = false;
if (this.pWt1 >= this.pWt2 && wt1 < wt2) {
if (this.obIndex < i && this.obIndex > this.crossunderIndex) {
this.crossunderIndex = i;
sell = true;
// crossover from oversold
if (this.pWt1 wt2) {
if (this.osIndex < i && this.osIndex > this.crossoverIndex) {
this.crossoverIndex = i;
buy = true;
this.pWt1 = wt1;
this.pWt2 = wt2;
return {
waveTrend: wt1,
waveTrendSmooth: wt2,
ob1: this.props.overbought1,
ob2: this.props.overbought2,
os1: this.props.oversold1,
os2: this.props.oversold2,
mid: 0,
buy,
sell,
buyColor: this.props.buyColor,
sellColor: this.props.sellColor,
filter(_, i) {
return i >= this.props.averageLength && i >= this.props.channelLength;
function tradePlotter(canvas, indicatorInstance, history) {
for(let i=0; i 0) {
if (item.buy || item.sell) {
const x = p.x.get(item);
const item1 = history.get(i - 1);
const x1 = p.x.get(item1);
const y = item.buy ? Math.min(item.waveTrend, item.waveTrendSmooth) : Math.max(item.waveTrend, item.waveTrendSmooth)
canvas.drawLine(
p.offset(x1, y),
p.offset(x, y),
color: item.buy ? item.buyColor : item.sellColor,
relativeWidth: 2,
opacity: 1.0
module.exports = {
description: "Wave Trend Oscillator",
calculator: waveTrendOscillator,
params: {
channelLength: predef.paramSpecs.period(10),
averageLength: predef.paramSpecs.period(21),
smoothLength: predef.paramSpecs.period(4),
cciConstant: predef.paramSpecs.number(0.015, 0.001, 0.001),
overbought1: predef.paramSpecs.period(60),
overbought2: predef.paramSpecs.period(53),
oversold1: predef.paramSpecs.period(-60),
oversold2: predef.paramSpecs.period(-53),
buyColor: predef.paramSpecs.color('cyan'),
sellColor: predef.paramSpecs.color('magenta'),
tags: [predef.tags.Oscillators],
areaChoice: meta.AreaChoice.NEW,
inputType: meta.InputType.BARS,
plots: {
waveTrend: { title: "Wave Trend"},
waveTrendSmooth: { title: "Wave Trend Smoothed"},
ob1: { title: "Overbought 1", displayOnly: true},
ob2: { title: "Overbought 2", displayOnly: true},
os1: { title: "Oversold 1", displayOnly: true},
os2: { title: "Oversold 2", displayOnly: true},
mid: { title: "Mid", displayOnly: true},
plotter: [
predef.plotters.singleline("waveTrend"),
predef.plotters.singleline("waveTrendSmooth"),
predef.plotters.singleline("ob1"),
predef.plotters.singleline("ob2"),
predef.plotters.singleline("os1"),
predef.plotters.singleline("os2"),
predef.plotters.singleline("mid"),
predef.plotters.custom(tradePlotter),
schemeStyles: {
dark: {
waveTrend: predef.styles.plot("#00C0C0"),
waveTrendSmooth: predef.styles.plot("#C000C0"),
ob1: predef.styles.plot("#FF0000"),
ob2: predef.styles.plot({ color: "#FF0000", lineStyle: 3 }),
os1: predef.styles.plot("#00FF00"),
os2: predef.styles.plot({ color: "#00FF00", lineStyle: 3 }),
mid: predef.styles.plot("#707070"),
[2022-07-18 18:14:29]
anyone?
[2022-07-18 21:10:43]
JohnR - User831573 - Posts: 328
You might try directly reaching out to some of the people listed on the SC 3rd party page.
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
JohnR
[2022-07-18 22:40:50]
SC Support Tom - Posts: 450
If you can accept this version, then I can do it. I do not have time to learn Tradeovate's proprietary language, but I know Tradingview's pretty well.
// @author LazyBear
// If you use this code in its original/modified form, do drop me a note.
study(title="WaveTrend [LazyBear]", shorttitle="WT_LB")
n1 = input(10, "Channel Length")
n2 = input(21, "Average Length")
obLevel1 = input(60, "Over Bought Level 1")
obLevel2 = input(53, "Over Bought Level 2")
osLevel1 = input(-60, "Over Sold Level 1")
osLevel2 = input(-53, "Over Sold Level 2")
ap = hlc3
esa = ema(ap, n1)
d = ema(abs(ap - esa), n1)
ci = (ap - esa) / (0.015 * d)
tci = ema(ci, n2)
wt1 = tci
wt2 = sma(wt1,4)
plot(0, color=gray)
plot(obLevel1, color=red)
plot(osLevel1, color=green)
plot(obLevel2, color=red, style=3)
plot(osLevel2, color=green, style=3)
plot(wt1, color=green)
plot(wt2, color=red, style=3)
plot(wt1-wt2, color=blue, style=area, transp=80)
[2022-07-18 23:17:40]
Thank you Tom,
I'd be willing to use it but not sure how to input your code into SC
[2022-07-19 00:07:51]
I can input the code into SC.
[2022-07-19 16:39:21]
Thank you!
[2022-07-26 09:13:28]
I am still working on this. Normally, oscillators take on values from -100 to +100. But this one takes on very high values (due to the factor of 0.015 in the denominator of the Composite Index). I am trying to get to the bottom of this.
[2022-07-26 10:22:49]
THank you so much , let me know if anyway I can help
[2022-08-18 21:03:15]
User658125 - Posts: 20
I just came across this thread as I was searching for the very same thing. Did the code get completed or is it still a work in progress?
[2022-08-18 22:37:03]
Still a work in progress
[2022-08-19 02:26:10]
Ackin - Posts: 1865
User658125)
It's possible download it for free + HA modified version
contact link:
Date Time Of Last Edit: 2022-08-19 02:26:45
imageWaveTrend.png / V - Attached On 2022-08-19 02:26:39 UTC - Size: 97.09 KB - 174 views
[2023-01-04 19:46:29]
This is done. It will be available in the next release.
