Date/Time: Sat, 15 Mar 2025 02:42:07 +0000
Coloring for delta study in footprint chart
View Count: 408
[2022-07-13 20:17:21] |
countryboy92 - Posts: 91 |
(Footprint .cht file provided by User is not attached to this Support Board Post) I need assistance adding the red and green coloring to the delta study at the bottom of this footprint chart. Thanks Date Time Of Last Edit: 2022-07-13 20:17:48
[2022-07-13 21:07:24] |
John - SC Support - Posts: 38678 |
In general, if you are wanting the colors to match the colors you have set for your Main Price Graph, then there is an option at the top of the Subgraph tab of the study settings window that states Use Chart Graphics Settings for Subgraph Colors. If you enable this option, then you will have the same coloring. Refer to the following: Chart Studies: Subgraphs Tab >> Use Chart Graphics Settings for Subgraph Colors Otherwise, you would need to adjust the High/Low/Open/Close subgraph colors within the study to get them how you want them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
