Date/Time: Sun, 02 Feb 2025 11:01:25 +0000
Numbers bars help needed
View Count: 872
[2022-07-13 16:24:43] |
User989035 - Posts: 5 |
Hello. Its been a week since im hardly trying on different symbols like BTC , ETH, BURGER, BEAM and so on to set up correctly and get the right details. I have browsed to many instructions , many videos without any luck Is there any chance you can guide me how to setup the correctly ? I see tons of details with numbers like 1212120012000012 . I want to be looking at the DELTA , BUY volume - Sell volume I want to use it in a time frame like 5 mins or 15 mins, I dont want to use it with ranges Tried so many things. Never managed to set it up properly. If looking at a normal chart i see a volume for 5 min of 1million, then when i insert the number bars i see tens of lines with such a big numbers that does not make up till 1million for example. Im getting more and more confused. Please help |
[2022-07-13 17:03:19] |
John - SC Support - Posts: 37656 |
The crypto currencies have very dense data that it makes the Numbers Bars difficult to work with. What you really need to do is to change the Chart >> Chart Settings >> Chart Data >> Volume at Price Multiplier for Intraday Chart to at least 100. You may need to try 200 or even as high as 1000. You will have to play with this number until you find something that works well for you. Refer to the information here: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-13 17:45:46] |
i did that, its somehow working but it is still not showing correct data. NUMBERS are extremely high and does not represent the real DELTA or volume?
[2022-07-13 17:58:44] |
Please give us a screenshot of what you are seeing and point out what is wrong and why. Refer to the following instructions for how to get us a screenshot: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-13 18:14:34] |
https://www.sierrachart.com/image.php?Image=1657736016828.png values are unreal. this cannot be trading volume for 5 mins. please explain me where is my mistake. |
[2022-07-14 10:04:39] |
[2022-07-14 14:59:27] |
Those are the values that we are given by the exchange. You would need to ask the exchange how they calculate volume for that instrument.
[2022-07-14 15:48:50] |
I know where is the problem. I need divider and remove several 0s from them. How is this done please ?
[2022-07-14 15:58:51] |
For the Numbers Bars there is a direct Input for the study that can change the decimal place to the left. Refer to the following: Numbers Bars: Volume Display Multiplier For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
