Date/Time: Sun, 04 Oct 2026 17:24:30 +0000
Saved Study - Analysis Subinstance
View Count: 672
| [2022-07-13 14:44:41] |
| Steve Leon - Posts: 319 |
If i have a saved study in the analysis section of my main instance is it supposed to show up in a subinstance after restarting the platform ? How can i get the saved study into the subinstance ? Thank you |
| [2022-07-13 15:54:26] |
| John - SC Support - Posts: 48095 |
You would need to copy the study to the sub-instance. Refer to the following information: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Copying Files Between Instances For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
