Date/Time: Tue, 22 Sep 2026 00:06:40 +0000
Export data periodically
View Count: 675
| [2022-07-13 11:11:21] |
| User980952 - Posts: 13 |
Hello, How can I export data periodically or real time in a .csv, .text or excel ? Thanks |
| [2022-07-13 14:56:58] |
| John - SC Support - Posts: 47955 |
Refer to the following study: Write Bar Data to File There is also a "Write Bar and Study Data to File" study, if that is what you need. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
