Date/Time: Sat, 15 Mar 2025 02:42:09 +0000
[User Discussion] - Datafeed Request
View Count: 503
[2022-07-13 10:05:00] |
Peter Simard - Posts: 6 |
I am looking for a real time data feed provider. I am not a professional trader. I have developed a trading system which requires a real time data feed. I am currently using Intrinio’s data feed service but the plan I am on is being discontinued and I need to locate a cheap data feed provider. Can you · provide the cost of your service? · Is it available with Microsoft .NET Technologies (pre .NET 5) · How many quotes are allowed at one time · If number of quotes is limited – can they be adjusted Peter |
[2022-07-13 10:52:56] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. · provide the cost of your service?
Pricing can be found here:Description of Service Packages and Pricing · Is it available with Microsoft .NET Technologies (pre .NET 5)
No definitely not. We do not use this .net and never would.· How many quotes are allowed at one time · If number of quotes is limited – can they be adjusted There are no limits imposed.
[2022-07-13 11:13:48] |
NYSE/NASDEQ/AMEX is there a web service available to connect to the data feed service? |
[2022-07-13 11:44:51] |
No. You can only access this data from within Sierra Chart due to exchange rules.
[2022-07-13 12:02:57] |
how is this used Data and Trading Communications (DTC) Protocol Server Data and Trading Communications (DTC) Protocol Server |
[2022-07-14 11:40:28] |
is it possible to use DTC to connect to Sierra Chart and receive real time data. If so - is there a limit of number of stocks that can be requested to stream?
