Date/Time: Sat, 15 Mar 2025 02:34:53 +0000
Service Package
View Count: 335
[2022-07-13 01:21:40] |
User989530 - Posts: 33 |
Hello, what is the Service Package required in order to use BitMex? Is there any guide to set the Service Settings, API Key, API Secret, Leverage, etc? Regards |
[2022-07-13 11:15:10] |
Any service package can be used. We do not provide documentation for BitMex any longer. Hopefully the settings are self-explanatory.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-13 11:15:17
