Date/Time: Tue, 26 Nov 2024 06:57:06 +0000
My chartbook does not work, need to convert it Please
View Count: 694
[2022-07-12 20:26:18]
User795767 - Posts: 2
My CHT don't work. Need to Convert it!
"the chartbook file is not compatible. Contact sierra chart support for help with converting it"
Have 2 files.
attachmentRKTZ_BTC.Cht - Attached On 2022-07-12 20:25:36 UTC - Size: 369.52 KB - 134 views
attachmentRKTZ_ETH.Cht - Attached On 2022-07-12 20:25:48 UTC - Size: 312.87 KB - 191 views
[2022-07-12 21:26:58]
John - SC Support - Posts: 36286
Attached are the updated files.
attachmentRKTZ_BTC.Cht - Attached On 2022-07-12 21:26:51 UTC - Size: 17.14 KB - 367 views
attachmentRKTZ_ETH.Cht - Attached On 2022-07-12 21:26:55 UTC - Size: 15.65 KB - 216 views
[2022-07-12 22:15:07]
Thanks in advance. Also Can you help me with another problem? Getting this error:
The Advanced custom study needs to be recompiled to be used on this version : 2411
Private File
Private File
[2022-07-13 14:25:20]
We can not do anything with those as they are the executable files.
If you have the original .cpp files (source code files) then you can recompile them, although they may need some slight updates. Refer to the following for how to compile the source code:
How to Build an Advanced Custom Study from Source Code
Otherwise, you will need to talk to whomever developed them for you and have them update them.
[2023-09-25 12:48:34]
User693923 - Posts: 5
Hi guys,
I do have the same issues and my chart books won't open.
The message is the same:
Can you please help me out with this? Attached are my chartbooks. (or at least the first 3 of 6)
Many thanks!
Private File
Private File
Private File
[2023-09-25 12:50:21]
And here are the other chartbooks.
Many thanks for your help.
Best
Private File
Private File
Private File
[2023-09-25 17:54:36]
The instructions to perform the update are at the following link:
Chartbooks (Workspaces): Opening Older Chartbooks
We no longer do the updates for older chartbooks.
[2023-12-27 22:35:16]
CryptoChecks - Posts: 2
Private File
[2023-12-27 23:25:18]
Private File
[2023-12-28 15:23:07]
You need to get a new chartbook from G7FX.
