Date/Time: Sat, 15 Mar 2025 02:42:09 +0000
Dark Windows while uploading attached chartbook
View Count: 437
[2022-07-12 20:10:45]
User509533 - Posts: 69
I am seeing dark Windows while uploading attached chart book.
Please see the attached screenshot and the chartbook causing the problem.
Thank you!
imageScreenshot from 2022-07-09 12-18-05.png / V - Attached On 2022-07-12 20:07:27 UTC - Size: 27.68 KB - 113 views
attachmentSZS ES.Cht - Attached On 2022-07-12 20:08:04 UTC - Size: 83.78 KB - 143 views
[2022-07-12 21:45:51]
John - SC Support - Posts: 38678
The following is a link to what we see when we open your chart. We are not seeing any issues at all.
https://www.sierrachart.com/image.php?Image=1657662216426.png
The only thing we can think is that you may have accidentally stopped the loading of the chart. It did take us a few minutes to get all the data loaded for that particular chart (#6), since it has 365 days of a Continuous Contract to load. You may have clicked on the window that shows the status, which cancels the load.
Make sure that chart is the active chart and select the "Insert" key on your keyboard to recalculate and reload that chart and see if it loads up.
