Date/Time: Sat, 15 Mar 2025 03:47:24 +0000
Charts look different
View Count: 431
[2022-07-12 18:18:33] |
User312053 - Posts: 10 |
I have a 13 tick heikin ashi chart on 2 different chartbooks. All of the settings are the same as far as i can tell, yet the bars print differently. How can i fix this?
[2022-07-12 21:08:58] |
John - SC Support - Posts: 38678 |
There has to be something different between the two charts. Refer to the following: Chart Studies: Resolving Study Differences For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-13 11:12:09] |
Refer to: Working With Charts: Resolving Differences of Chart Bars Between Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
