Date/Time: Thu, 28 Nov 2024 23:51:58 +0000
My chartbook does not work, need to convert it Help
View Count: 737
[2022-07-12 17:42:34]
Sivle - Posts: 53
my chart book does not work
i tried to open it in sierra chart and i got this message
the chartbook file is not compatible. Contact sierra chart support for help with converting it
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-07-12 17:41:53 UTC - Size: 276.18 KB - 306 views
[2022-07-12 18:16:45]
John - SC Support - Posts: 36350
Attached is the updated chartbook.
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2022-07-12 18:16:42 UTC - Size: 20.56 KB - 258 views
[2022-07-12 18:43:18]
Sivle - Posts: 53
Thanks.
I have a question.
Why do we need to convert the chartbooks. Is it because of update of sierra chart itself ?
Or is the files corrupt damaged?
And do we need to contact sierra chart always when this happens or can we do it ourselfs?
Just curious.
Date Time Of Last Edit: 2022-07-12 18:43:30
[2022-07-12 21:11:06]
It's just when moving from an older release to the more recent releases. We have made extensive changes to the chartbook files, so you can not always open them directly in the newer version. Refer to the information here:
Chartbooks (Workspaces): Opening Older Chartbooks
