Date/Time: Tue, 26 Nov 2024 11:26:42 +0000
Trying to set up an automated spreadsheet; getting multiple arrows for buy/sell
View Count: 948
[2014-05-07 14:57:29] |
User89272 - Posts: 3 |
I'm trying to set up a spreadsheet and noticed the following... When a Buy Entry (or sell entry) becomes TRUE, arrows appear not only at the entry but at every other bar on the chart. In looking at the spreadsheet,whenever the formula becomes true... the "true" is propagated down the entire spreadsheet ! This seems to be the reason for all the arrows, but WHY the propagation ? In my way of thinking, the "TRUE" only happened at a specific ROW (???? 3 to be exact) WHy even bother propagating it ?
[2014-05-07 17:32:33] |
The question is what is the formula you are using specifically? Something about the formula is evaluating to TRUE at all rows.
