Date/Time: Sat, 15 Mar 2025 02:39:41 +0000
How do i buy
View Count: 470
[2022-07-12 17:22:27] |
Sivle - Posts: 67 |
How do i buy Base Sierra chart with Advanced Features (Service package 5) ? i want to be able to use TPO and market profile, volumeprofile. I don't care if the data is delayed. When i go to activate services and i see the available services the default is base standard 26 usd/month i guess its service package 3. But i want service package 5? wich should i choose? should i choose Base Advanced - 36 usd /month <------ is this service package 5 ? Thanks for a fast respons |
[2022-07-12 17:39:39] |
John - SC Support - Posts: 38678 |
Based Advanced for $36.00/month is Package 5. The package number is listed to the left side of the descriptions in the services menu. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-12 17:45:20] |
Sivle - Posts: 67 |
can you help me with my problems involving my chartbook. my chartbook does not work. i get the message the chartbook file is not compatible. Contact sierra chart support for help with converting it |
[2022-07-12 18:18:13] |
Please attach the chartbook to this thread and we will update it for you. Follow these instructions to attach the chartbook: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-12 18:18:31
