Date/Time: Sat, 15 Mar 2025 03:54:32 +0000
calculation moving average heikin ashi
View Count: 481
[2022-07-12 15:32:15] |
User356540 - Posts: 5 |
hello, > please specify in a renko chart (blanked) with heikin ashi candles in chart region 1 is > the calculation of a moving average made with the closing prices > heihin ashi or renko price (same question for the opening, higher and > lower) I would like with the heiken ashi award? > > JL LeB |
[2022-07-12 17:17:59] |
John - SC Support - Posts: 38678 |
If you have enabled the option on the Heikin-Ashi study to Display as Main Price Graph, then when you add a Moving Average and leave the Based On set to Main Price Graph, then the Moving Average will be based on the information from the Heikin-Ashi study. But, if you do not have the option for Display as Main Price Graph, but just have the Heikin-Ashi displayed, then you would need to set the Moving Average Based On setting to be for the graph that you want (either Main Price Graph or Heikin-Ashi). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
