Date/Time: Sat, 15 Mar 2025 03:45:01 +0000
Make a call from external app to switch a chart on Sierra chart app
View Count: 394
[2022-07-12 15:31:17] |
bslusarek - Posts: 1 |
Hi, I m considering adding a Sierra chart to my system. I would like to be able to make a call (API or TCP) to Sierra chart to display a chart with given security. Is something like this supported? Thanks, Ben |
[2022-07-13 16:13:35] |
Sierra_Chart Engineering - Posts: 18789 |
Yes this is fully supported. You can use ACSIL to open charts: ACSIL Interface Members - Functions: sc.OpenChartOrGetChartReference() You can also use the UDP functionality for this: UDP Interface We activated your Sierra Chart account. So you can do testing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-13 16:14:09
