Date/Time: Sat, 19 Sep 2026 20:48:38 +0000
Minimum MBO Qty
View Count: 678
[2022-07-12 15:29:21]
Sargon Petros - Posts: 57
Hi there,
Could you tell me if the Minimum MBO Order field in Global Symbol settings is only applicable to the primary instance? When I use this setting with multiple instances, it doesn't seem to apply except for the primary, regardless if I change it in the other instances.
Thank you
[2022-07-13 16:04:16]
Sierra_Chart Engineering - Posts: 24892
It affects the primary instance and any sub instances that are connected to the primary instance.
You would not want to change this in a sub instance. In a sub instance leave the setting at 0.
We will update the documentation in this regard.
