Date/Time: Sat, 15 Mar 2025 03:47:21 +0000
Scale out disfunction - v2411
View Count: 399
[2022-07-12 15:15:18] |
User993067 - Posts: 174 |
latest version..scale out difficulty bracket order qty does not adjust current position, resulting in double fills, with unbracketed new position. 1. scale in is normal using DOM, trade window or control bar shortcuts 2. scale out using trade window radio buttons or control shortcut commands bracket orders do not update to current qty after scale out. 3. They update correctly when scaling out using limit orders in the DOM. 4. if the first scale out is with limit order in the DOM, then remaining scaled orders will update properly using TW or CB |
![]() Attachment Deleted. |
[2022-07-12 15:47:54] |
Make sure this option is disabled: Global Settings >> Global Trade Settings >> Scale In/Out >> Perform Immediate Scale Out with Market Order And update to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
