Date/Time: Sun, 16 Mar 2025 02:55:03 +0000
Change in setting does not take effect
View Count: 409
[2022-07-12 14:06:00]
User181801 - Posts: 42
Hello and thank for your help,
I am trying to change the following setting on my weekly TPO CL chart from 1440 to 30. I hit apply and it changes back to 1440.
"TPO letter/block time period length (for intraday charts) In:5"
The problem seems to affect only my CL weekly tpo, other contracts work well.
Is there something I can do?
[2022-07-12 16:35:20]
John - SC Support - Posts: 38678
Weekly and higher TPO charts are automatically set to a specific "TPO Letter/Block Time Period Length" in order to not cause extremely long calculations. This can not be changed.
[2022-08-08 15:51:27]
Radu Sirbu - Posts: 40
I have the same issue like User181801 with Weekly TPO.
For weekly you should set the block time period length to 4 hours or 1 hour, but not 1 day. It is totally absurd to have a weekly TPO with only 5 blocks. It doesn't' help the trader at all.
[2022-08-08 19:28:37]
As long as the chart is an Intraday chart, then you can set the Period time as you want. It is just when it is an Historical chart that you can not change it.
[2022-08-08 20:18:10]
thanks for the tip!
