Date/Time: Sat, 15 Mar 2025 03:49:46 +0000
Volume Value Lines / TPO Value Lines
View Count: 546
[2022-07-12 10:23:04] |
User737477 - Posts: 19 |
Hi guys, I'm wondering if you could help me fix the issues that I'm having with one of these intraday chart indicators please? I currently have a TPO chart [showing volume based POC and VAH/VAL]. This TPO chart splits the day session from the evening session and draws separate TPO profiles etc. I'm trying to reproduce the implied VVAH/VVAL/VPOC lines onm a second chart which is intra-day [5min candles]. Session are set according to those within the TPO chart. when I overlay the Volume Value Area Lines study, and set the lookback period to 0 [i.e. just to show the current profile dynamics], I can reconcile them to the TPO chart which is great. The issue arises when I then switch the lookback period to 1 - the study then plots the lines but misses the immediately adjecent period out. Example: If current day = Tuesday evening. The study plots the lines on a lookback =1 basis to those of the Monday evening, thus bypassing the Tuesday day session. The order of sessions: Monday day, Monday evening, Tuesday day, Tuesday evening and so on. If looking at Thursday day, the lines plotted refer to Wednesday day and not Wednesday evening etc. I'd like the lines to refer to the session immediately prior i.e. for Thursday day session to show lines from Wednesday evening and so on.... I've had a play around with the settings but no luck as yet. For reference, the study parameters are set as per the attached. Note that the tick sizes between charts is set consistently. Many thanks, Alun |
[2022-07-12 15:55:49] |
John - SC Support - Posts: 38678 |
If we are understanding you correctly, you want to show the Evening Session VVAH/VVAL/VPOC on the previous Day Session and then the preceding Day Session on the Evening Session before it, etc. This particular situation is not supported. When you are setting the number of periods back, it is shifting by the entire trading day, so Evening Sessions line up with Evening Sessions and Day Sessions with Day Sessions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
