Date/Time: Tue, 26 Nov 2024 11:52:00 +0000
Version 1132: Countdown Timer Issues.
View Count: 1041
[2014-05-07 14:02:27]
User62933 - Posts: 17
The issue started, after upgrading to 1132. I have Countdown Timers visible on all my charts. I have chart #4 configured to copy "drawings" from chart #3. It still works, however, now the countdown timer from chart #3 is also showing up on chart #4, and I cannot remove it. I was going to roll back to previous version, but then I will lose this newly created chart book, as the versions are not compatible.
Thank you.
[2014-05-07 15:54:37]
Futures Operator - Posts: 239
A temporary fix is to remove and re-add the countdown timer study from the charts.
[2014-05-07 16:41:31]
You need to remove the Countdown Timer study from the chart and add it again.
You should not have a problem using a Chartbook saved in a newer version in an earlier Sierra Chart version. Although this depends upon how far back the earlier version is. If it is a version within approximately the last 6 months it will not be a problem.
Date Time Of Last Edit: 2014-05-07 16:41:48
[2014-05-07 17:56:52]
Thank you, I removed the study, and reinserted, and it is working fine now. However, it would not let me adjust the position of the counter on the chart.
[2014-05-07 18:08:39]
We see no problems with moving the countdown timer study on version 1132. However, it can only be moved on the chart where it is added.
You need to right-click on it and select Move Drawing. If you do not see that command you need to add it through Global Settings >> Customize Chart Drawing Menu.
Date Time Of Last Edit: 2014-05-07 18:09:21
[2014-05-07 21:08:12]
Yes, got it. Thank you very much.
