Date/Time: Sat, 15 Mar 2025 02:34:55 +0000
suggestion
View Count: 332
[2022-07-11 18:24:52]
User427561 - Posts: 217
it is suggested an be very helpful if a time column be added to the alert manager window
thanks
[2022-07-11 19:09:25]
There is one. There is a Date-Time column.
Use the scroll bar at the bottom if it is not visible. You can also drag it to another position.
[2022-07-11 19:17:21]
it is mingled up with anothher item study. would rather see it as a stand alone column
