Date/Time: Sat, 15 Mar 2025 02:32:31 +0000
cant link My account from amp futures to sierra charts
View Count: 433
[2022-07-11 17:02:38] |
User632679 - Posts: 1 |
Hi cant link account # could not link account and real money! Please help!! Thank you |
[2022-07-11 19:03:06] |
John - SC Support - Posts: 38678 |
Since your account is with AMP, then most likely they have you setup with CQG for your order routing. If this is the case, then you need to follow the instructions at the following link to connect your Sierra Chart to your CQG account: CQG Trading Platform Service: Setup Instructions After you do the above, you will want to open your chartbooks and select Edit >> Translate Symbols to Current Service to ensure your symbols are setup for CQG. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
