Date/Time: Sat, 15 Mar 2025 02:37:20 +0000
Installation issue
View Count: 358
[2022-07-11 17:02:22]
User528721 - Posts: 1
Hello
Could you tell me which service plan I need and how much to pay to continue
with the simulator product, the same as the free trial.
I am also having trouble opening the charts after downloading the software.
Hoping you can help with this. Screenshot attached.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=66642
[2022-07-11 19:01:19]
John - SC Support - Posts: 38678
If you are going to use the Delayed Streaming data with our Trading Evaluator service, then you would one of our Base packages (package 3 or 5) depending on your indicator needs. Refer to the information on these packages here:
Description of Service Packages and Pricing: Base Packages
With regards to the software update, we see you are on a MAC, and typically the issue is related to the path to the data, which our installer does not understand. We recommend using our Zip installer instead. Refer to the information here:
Software Download: Sierra Chart Zip Installer
