Date/Time: Sat, 15 Mar 2025 03:47:23 +0000
How to backup Sierra Chart
View Count: 512
[2022-07-11 16:54:17] |
User181 - Posts: 7 |
I want to back up the data of the chart folder and the historical lineation, and the whole backup to another computer for normal use
[2022-07-11 18:51:36] |
John - SC Support - Posts: 38678 |
Refer to the information at the following link which will give you the information you need, depending on what you wan to backup: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
