Date/Time: Sat, 15 Mar 2025 02:37:20 +0000
MBO - Adjusting Minimum Quantity to Display
View Count: 757
[2022-07-11 16:33:24]
Dan the Man - Posts: 92
I have package 12.
I'm trying to adjust the MBO size to 20 on the ES
I followed "Adjusting Minimum Quantity to Display for Market by Order Data" and "Step-by-Step Instructions"
It doesn't seem to matter what I do, I always have 3 and greater displayed.
I attached a screen shot.
I don't know how to resolve this.
King Regards,
imageMBO.png / V - Attached On 2022-07-11 16:32:14 UTC - Size: 80.17 KB - 343 views
[2022-07-11 18:30:42]
John - SC Support - Posts: 38678
We can not tell from your image, but typically when this occurs it is because you are using a Trade and Current Quote Symbol. In which case, you need to make the change for the symbol that is used in that field. Refer to the following:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
[2022-07-11 20:29:25]
Hi John,
Thanks for the quick reply,
I believe I followed the directions but still no MBO size filter.
I left the Trade and Current Quote Symbol blank, that way the Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol menu) wouldn't apply (I think).
Kind Regards,
imageMBO-1.png / V - Attached On 2022-07-11 20:27:39 UTC - Size: 144.43 KB - 155 views
[2022-07-11 21:38:44]
You are changing the MBO minimum quantity for the ES Spreads. You need to adjust the symbol F.US.EP?##. In other words, it needs to be the same symbol as you are using in your chart.
[2022-07-11 22:57:16]
Oops,
Thanks, John
Kind Regards,
