Date/Time: Sat, 15 Mar 2025 03:52:09 +0000
No Service instance - Creating custom symbol
View Count: 394
[2022-07-11 14:30:09] |
rxtrading - Posts: 33 |
Hello, I run a separate instance for analyzing custom data sets within an offline version. Most of these data sets are in CSV. Two questions: 1) is it possible to create a symbol and link it to the CSV file? 2) Assuming I'm able to create a symbol for that data, can I append just append the data to the CSV and it automatically reads the changes? |
[2022-07-11 18:20:40] |
John - SC Support - Posts: 38678 |
You can do what you want if the data is Daily Historical data, as those files are ASCII data files. Refer to the information starting here: Text/CSV Data Format: General But there is not a direct way to do this for Intraday data. You would have to develop a custom study to do this. Refer to the information on custom studies starting here: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
