Date/Time: Sat, 15 Mar 2025 03:47:21 +0000
Denali CME Options
View Count: 495
[2022-07-11 13:36:39] |
User143681 - Posts: 45 |
Hello, upgraded to Denali and connecting through CQG, that's been my selected service before upgrading but not sure if its the correct way to setup now. But was unable to trade options when connecting service was set to Denali. What's the correct setup using Denali data feed? When using Denali to trade options thought would change symbol format to e.g. E2AN22 but orders weren't sending. For now am using CQG format C.US.EP...with connecting service set to CQG. However, with auto set from data feed set to yes the options symbols increment is set 0.010000 and options price displays incorrectly in increments of one. I have read many posts but still missing something. Please advise the correct setting for using the Denali data feed service and options format and settings. Thank you. |
[2022-07-12 08:46:32] |
Sierra_Chart Engineering - Posts: 18789 |
You need to have Sierra Chart set to use CQG: CQG Trading Platform Service: Setup Instructions And refer to: Denali Exchange Data Feed: Denali Futures Options Data with Other Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
