Date/Time: Sat, 15 Mar 2025 02:39:42 +0000
cannot connect to Interactive Brokers data feed?
View Count: 406
[2022-07-11 00:40:54] |
Dean King - Posts: 1 |
I think I folle0wed the instructions correctly. I am running TWS on my Mac and Sierra on my laptop. Sierra is showing not connected?
[2022-07-11 08:16:02] |
TWS must be running on the same computer that Sierra Chart is running on. Is this the case? Otherwise, connectivity becomes more complicated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
