Date/Time: Sun, 24 Nov 2024 16:09:05 +0000
automatic fibonacci retracement beetween the donchian channel bands
View Count: 1114
[2022-07-10 18:28:17] |
User275592 - Posts: 97 |
Hi, i'd like to draw fibonacci retracement lines beetween the donchian channel bands. Is it possible to do this only with studies ? does it need study development ? thank you for your help |
[2022-07-11 16:31:53] |
We are not sure if this is what you want, but you can use the Donchian Channel as the inputs for the Fibonacci Bands study.
[2022-07-11 17:25:22] |
thank you for your message could you post a link to that study |
[2022-07-11 19:09:27] |
I do not know why, but we do not have any documentation at this time for the Fibonacci Bands. But the study is very straightforward and has an Input for what you want to use to define the bands (i.e. what input to use).
[2022-07-11 20:49:10] |
ok thank you
[2022-08-08 10:34:52] |
Hi, in fact, i am using a Donchian chanel and i'd like to draw fibonacci retracement inside the channel / the Study has an SG for the 50 % (Mid) but i'd like to draw the 61,8 % and the 38,2 too Maybe this way is more clear ? thank you for your help |
[2022-08-08 17:22:07] |
You would have to calculate those directly. You could use the Spreadsheet Study to do this where each column would be the particular level you want. Refer to the information starting here: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-08 18:15:45] |
ok thank you for your help I will try this Maybe i will be back here for some more help ;-) |
[2022-08-11 07:22:32] |
no more help needed ! I learned how to use spreadsheet (see the excellent step by step Using the Spreadsheet Study: Step By Step Instructions to use the Spreadsheet Study ) and with a few formulas, the fibonacci retracement inside donchian channel is working ... Thank you very much for your help Sierrachart = excellnt platform + excellent support |
