Date/Time: Sat, 15 Mar 2025 03:49:47 +0000
Forex Futures Data
View Count: 415
[2022-07-10 05:46:27] |
Moodzy89 - Posts: 7 |
Hi, Im im after live forex futures data do the level 10 packages provide this? Thanks |
[2022-07-11 15:54:58] |
John - SC Support - Posts: 38678 |
When you say Forex Futures are you referring to the CME Group FX futures such as 6A (Australian Dollar)? If this is the case, then you would use the Denali Exchange Data Feed to get this data, and for this you would need to be on Package 10 or higher (one of the Integrated Packages). Refer to the information here: Description of Service Packages and Pricing: Integrated Packages You would then need to go through the Setup Instructions for the CME Data on the Denali Exchange Data Feed at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
