Date/Time: Sat, 15 Mar 2025 02:32:30 +0000
How to match Fibonacci Fan to eSignals or TradingView's Fibonacci Fan?
View Count: 455
[2022-07-09 18:53:02] |
Techotomy - Posts: 104 |
The Fibonacci Fan for SC is significantly different than the one you see on TradingView's, which matches eSignal's. What input values are needed to match either platforms Fibonacci Fan and why does SC's differ?
[2022-07-09 20:00:54] |
After thinking about the geometry, the following values were found to replicate those fibs fans: 34.555 (golden ratio for resistance), 50, 59.54693, 66.667, 71.42857, 75 (0 line), 78.125, 81.25, 84.55, 87.5, 90.45 (golden ratio for speed), and 93.75. It would be cool if there was an option to add a price retracement box to the fib fan since those are commonly used together. Also, thank you so much for allowing precise connecting between highs and lows with the fib fan with a lot of decimal precision. The other trading programs suck hard in this regard, saying that fib fans should connect between highs and lows in their documentation without actually allowing you to connect the drawing tool to the highs and the lows. Date Time Of Last Edit: 2022-07-09 20:25:08
[2022-07-11 15:39:49] |
John - SC Support - Posts: 38678 |
Glad you were able to figure it out and thank you for the compliment.
